[ZLG-ARM] 请教版主。。。ARM的程序。
2492|1
 楼主| 彭菠菜 发表于 2007-5-23 09:49 | 显示全部楼层 |阅读模式
小弟是ARM的初学者,在看别人的程序时候有以下一段代码不明白。<br /><br /><br />void&nbsp;drvLcd_ReadResInConstArea(UInt32&nbsp;uiCJKFontIndex,UInt8&nbsp;*pDes,UInt32&nbsp;size)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;UInt32&nbsp;CJKOffset;<br />&nbsp;&nbsp;&nbsp;&nbsp;UInt32&nbsp;SizeOfOPermanentCode;<br />&nbsp;&nbsp;&nbsp;&nbsp;UInt32&nbsp;*AddressOffsetOfOdpRegion;<br />&nbsp;&nbsp;&nbsp;&nbsp;UInt32&nbsp;*AddressOffsetOfConstRegion;<br />&nbsp;&nbsp;&nbsp;&nbsp;UInt32&nbsp;result;<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$ISRAM_PERM_RO_CACHED$$Base;<br />&nbsp;&nbsp;&nbsp;&nbsp;__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$ODP_RO_CACHED_UMW$$Base;<br />&nbsp;&nbsp;&nbsp;&nbsp;__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$ODP_RO_UNCACHED_UMW$$Base;<br />&nbsp;&nbsp;&nbsp;&nbsp;__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$ISRAM_PERM_RO_UNCACHED$$Length;<br />&nbsp;&nbsp;&nbsp;&nbsp;__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$ISRAM_RW_UNCACHED$$Length;<br />&nbsp;&nbsp;&nbsp;&nbsp;__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$ISRAM_PERM_RO_CACHED$$Length;<br />&nbsp;&nbsp;&nbsp;&nbsp;__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$ISRAM_RW_CACHED$$Length;<br />&nbsp;&nbsp;&nbsp;&nbsp;__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$INT_VECT_AND_CODE$$Length;<br />&nbsp;&nbsp;&nbsp;&nbsp;__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$CONST_DATA$$Base;<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;if(pDes==NULL)<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;;<br />&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;<br /><br />其中:__weak&nbsp;extern&nbsp;unsigned&nbsp;int&nbsp;Image$$ISRAM_PERM_RO_CACHED$$Base;不明白是什么意思。<br />请各位大哥多多指教。
onimu 发表于 2007-5-23 13:54 | 显示全部楼层
應該是外部文件定義的變數
不過對這些變數的意義不太了解,求達人正解.
