改成后面这样, 程序会死在这里
if (__VECTOR_RAM != __VECTOR_TABLE)
for (n = 0; n < 0x104; n++)
__VECTOR_RAM[n] = __VECTOR_TABLE[n];
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Memory Regions-*/
define symbol __ICFEDIT_region_ROM_start__ = 0;
define symbol __ICFEDIT_region_ROM_end__ = (16*1024);//********
define symbol __ICFEDIT_region_RAM_end__ = 0x20000000;
define symbol __ICFEDIT_region_RAM_start__ =__ICFEDIT_region_RAM_end__ - (2*1024)/4 + 0x410;//********
/*-Specials-*/
define symbol __ICFEDIT_intvec_start__ = __ICFEDIT_region_ROM_start__;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = (1*1024);//********
define symbol __ICFEDIT_size_heap__ = (1*1024);//********
/**** End of ICF editor section. ###ICF###*/
define symbol __region_RAM2_start__ = 0x20000000;
define symbol __region_RAM2_end__ = __region_RAM2_start__ + ((2*1024)*3)/4;//********
define exported symbol __VECTOR_TABLE = 0x00000000;
/*define exported symbol __VECTOR_TABLE = __ICFEDIT_region_RAM_start__ - 0x410;*/
define exported symbol __VECTOR_RAM = __ICFEDIT_region_RAM_start__ - 0x410;
define exported symbol __BOOT_STACK_ADDRESS = __region_RAM2_end__ - 8;
define symbol __code_start__ = __ICFEDIT_region_ROM_start__ + 0x410;//********
define memory mem with size = 4G;
define region ROM_region = mem:[from __ICFEDIT_region_ROM_start__ to __ICFEDIT_region_ROM_end__];// | mem:[from __region_FlexNVM_start__ to
__region_FlexNVM_end__];//********
define region RAM_region = mem:[from __ICFEDIT_region_RAM_start__ to __region_RAM2_end__];// | mem:[from __region_RAM2_start__ to __region_RAM2_end__];
define block CSTACK with alignment = 8, size = __ICFEDIT_size_cstack__ { };
define block HEAP with alignment = 8, size = __ICFEDIT_size_heap__ { };
initialize manually { readwrite };
initialize manually { section .data};
initialize manually { section .textrw };
do not initialize { section .noinit };
define block CodeRelocate { section .textrw_init };
define block CodeRelocateRam { section .textrw };
place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };
place at address mem:__code_start__ { readonly section .noinit };
place in ROM_region { readonly, block CodeRelocate};
place in RAM_region { readwrite, block CodeRelocateRam,
block CSTACK, block HEAP };
