[DSP编程] DM642定时器中断问题
1021|1
 楼主| 596121344 发表于 2015-6-29 20:34 | 显示全部楼层 |阅读模式
刚学习DSP,写了一个DSP定时器中断的代码,总是不能响应定时中断,请大侠指点,主要代码如下,功能就是每次定时器中断时,收发一次传过来的声音。
/*SEEDDM642的emifa的设置结构*/
EMIFA_Config Seeddm642ConfigA ={
           0x00052078,/*gblctl EMIFA(B)global control register value */
                                     /*将CLK6、4、1使能;将MRMODE置1;使能EK2EN,EK2RATE*/
           0xffffffd3,/*cectl0 CE0 space control register value*/
                                     /*将CE0空间设为SDRAM*/
           0x73a28e01,/*cectl1 CE1 space control register value*/
                                     /*Read hold: 1 clock;
                                       MTYPE : 0000,选择8位的异步接口
                                       Read strobe :001110;14个clock宽度
                                       TA:2 clock; Read setup 2 clock;
                                       Write hold :2 clock; Write strobe: 14 clock
                                       Write setup :7 clock
                                               \                 14c                /1c
           0x22a28a22, /*cectl2 CE2 space control register value*/
       0x22a28a42, /*cectl3 CE3 space control register value*/
           0x57115000, /*sdctl SDRAM control register value*/
           0x0000081b, /*sdtim SDRAM timing register value*/
           0x001faf4d, /*sdext SDRAM extension register value*/
           0x00000002, /*cesec0 CE0 space secondary control register value*/
           0x00000002, /*cesec1 CE1 space secondary control register value*/
           0x00000002, /*cesec2 CE2 space secondary control register value*/
           0x00000073 /*cesec3 CE3 space secondary control register value*/
/********************************************************************//*设置定时中断采集,SEEDDM642的Timer0的设置结构*/
TIMER_Config MyConfig = {
  0x00000200, /* ctl */
  0x002124f8, /* prd,CPU主频为600MHz,即内部时钟源为75MHz,则定时周期为1ms */
  0x00000000  /* cnt */
/*SEEDDM642的IIC的设置结构*/
I2C_Config SEEDDM642IIC_Config = {
    0,  /* master mode,  i2coar;采用主模式   */
    0,  /* no interrupt, i2cimr;只写,不读,采用无中断方式*/
    (20-5), /* scl low time, i2cclkl;  */
    (20-5), /* scl high time,i2cclkh;  */
    1,  /* configure later, i2ccnt;*/
    0,  /* configure later, i2csar;*/
    0x4ea0, /* master tx mode,     */
            /* i2c runs free,      */
            /* 8-bit data + NACK   */
            /* no repeat mode      */
    (75-1), /* 4MHz clock, i2cpsc  */
CHIP_Config SEEDDM642percfg = {
        CHIP_VP2+\
        CHIP_VP1+\
        CHIP_VP0+\
        CHIP_I2C+\
        CHIP_MCASP0
I2C_Handle hSeeddm642i2c;
/*设置需打开的音频的句柄*/
SEEDDM642_AIC23_Handle dm642aic23handle0,dm642aic23handle1;
SEEDDM642_AIC23_Handle dm642aic23handle2,dm642aic23handle3;
/* Internal codec state used to simulate read/write functionality */
SEEDDM642_AIC23_Config codecstate = SEEDDM642_AIC23_DEFAULTCONFIG;
MCASP_Handle SEEDdm642codec;
extern far void vectors();
/*此程序可将四个采集口的数据经过Video Port0送出*/
void main()
/* perform all initializations                           */
        TIMER_Handle hTimer;
        Uint32 dwTimerEventId;
          /*定时器启动*/
        hTimer = TIMER_open(TIMER_DEV0, TIMER_OPEN_RESET);
        dwTimerEventId = TIMER_getEventId(hTimer);
        TIMER_config(hTimer, &MyConfig);
        TIMER_start(hTimer); //定时中断,间隔为1ms
        /*Initialise CSL,初始化CSL库*/
        CSL_init();
        CHIP_config(&SEEDDM642percfg);
        /*EMIFA的初始化,将CE0设为SDRAM空间,CE1设为异步空间
         注,DM642支持的是EMIFA,而非EMIF*/
        EMIFA_config(&Seeddm642ConfigA);
        /*中断向量表的初始化*/
        //Point to the IRQ vector table
    IRQ_setVecs(vectors);
    IRQ_nmiEnable();
    IRQ_globalEnable();
    IRQ_map(dwTimerEventId, 4);      //定时器0中断事件重新映射到4,即可屏蔽中断的最优先级, MUXH[25:21]=0×02
    IRQ_reset(dwTimerEventId);
    IRQ_enable(dwTimerEventId);
    IRQ_map(IRQ_EVT_VINT1, 11);     //EMU实时数据交换(RTDX)映射到11 MUXH[9:5]=0x0a
    IRQ_reset(IRQ_EVT_VINT0);
    IRQ_enable(IRQ_EVT_VINT0);
    IRQ_map(IRQ_EVT_VINT0, 12);     //EMU RTDX 发送   映射到12 MUXH[14:10]=0x0b
    IRQ_reset(IRQ_EVT_VINT1);
    IRQ_enable(IRQ_EVT_VINT1);
        /*AIC23B的初始化*/
        hSeeddm642i2c = I2C_open(I2C_PORT0,I2C_OPEN_RESET);
        I2C_config(hSeeddm642i2c,&SEEDDM642IIC_Config);
        /*第一通路AIC23工作在主模式*/
//        codecstate.regs[SEEDDM642_AIC23_DIGIF] = 0x13;
        dm642aic23handle0 = EVMDM642_AIC23_open(hSeeddm642i2c,0,&codecstate);
        /*MCASP的初始化*/
        SEEDdm642codec = SEEDDM642_AIC23_openCodec();
        /*音频的采集与回放*/
        for(;;)
interrupt void timer0(void)
        Uint32 codecdata;
        if(MCASP_FGETH(SEEDdm642codec,RSTAT,RDATA))
                        codecdata= MCASP_RGETH(SEEDdm642codec,RBUF1);
                        MCASP_RSETH(SEEDdm642codec,XBUF0,codecdata);
                else
                            asm(" nop");
     IRQ_clear(TIMER_DEV0);
 楼主| 596121344 发表于 2015-7-1 17:09 | 显示全部楼层
自己顶,哪位大神帮忙检查一下,到底问题出在哪
