[STM32F1]
USB接收的问题
819|4
JY-DX-JY|  楼主 | 2015-7-4 12:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近要用STM32搞USB,片子是RBT6,找了几个例程。
要用到USB通讯,发送和接收。
JoyStickMouse.part01.rar (3 MB)
JoyStickMouse.part02.rar (3 MB)
JoyStickMouse.part03.rar (2.22 MB)
JY-DX-JY|  楼主 | 2015-7-4 12:52 | 只看该作者
int main(void)
#ifdef DEBUG
  debug();
#endif
  Set_System();
  Set_USBClock();
  USB_Config();
  USB_Init();
  Speaker_Config();
  while (1)
这是USB音响例程的主函数
void USB_HP_CAN_TX_IRQHandler(void)
  CTR_HP();
* Function Name  : USB_LP_CAN_RX0_IRQHandler
* Description    : This function handles USB Low Priority or CAN RX0 interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_LP_CAN_RX0_IRQHandler(void)
  USB_Istr();
这是发送和接收中断。
void USB_Istr(void)
  wIstr = _GetISTR();
#if (IMR_MSK & ISTR_RESET)
  if (wIstr & ISTR_RESET & wInterrupt_Mask)
    _SetISTR((u16)CLR_RESET);
    Device_Property.Reset();
#ifdef RESET_CALLBACK
    RESET_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_DOVR)
  if (wIstr & ISTR_DOVR & wInterrupt_Mask)
    _SetISTR((u16)CLR_DOVR);
#ifdef DOVR_CALLBACK
    DOVR_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_ERR)
  if (wIstr & ISTR_ERR & wInterrupt_Mask)
    _SetISTR((u16)CLR_ERR);
#ifdef ERR_CALLBACK
    ERR_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_WKUP)
  if (wIstr & ISTR_WKUP & wInterrupt_Mask)
    _SetISTR((u16)CLR_WKUP);
    Resume(RESUME_EXTERNAL);
#ifdef WKUP_CALLBACK
    WKUP_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_SUSP)
  if (wIstr & ISTR_SUSP & wInterrupt_Mask)
    /* check if SUSPEND is possible */
    if (fSuspendEnabled)
      Suspend();
    else
      /* if not possible then resume after xx ms */
      Resume(RESUME_LATER);
    /* clear of the ISTR bit must be done after setting of CNTR_FSUSP */
    _SetISTR((u16)CLR_SUSP);
#ifdef SUSP_CALLBACK
    SUSP_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_SOF)
  if (wIstr & ISTR_SOF & wInterrupt_Mask)
    _SetISTR((u16)CLR_SOF);
    bIntPackSOF++;
#ifdef SOF_CALLBACK
    SOF_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_ESOF)
  if (wIstr & ISTR_ESOF & wInterrupt_Mask)
    _SetISTR((u16)CLR_ESOF);
    /* resume handling timing is made with ESOFs */
    Resume(RESUME_ESOF); /* request without change of the machine state */
#ifdef ESOF_CALLBACK
    ESOF_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_CTR)
  if (wIstr & ISTR_CTR & wInterrupt_Mask)
    /* servicing of the endpoint correct transfer interrupt */
    /* clear of the CTR flag into the sub */
    CTR_LP();
#ifdef CTR_CALLBACK
    CTR_Callback();
#endif
#endif
} /* USB_Istr */
这是中断处理子程序,
发现只接收了个状态,怎么找不到接受数据呢?
高手指教,谢谢!
JY-DX-JY|  楼主 | 2015-7-5 09:50 | 只看该作者
高手支招啊!
JY-DX-JY|  楼主 | 2015-7-5 12:59 | 只看该作者
没人知道吗?
JY-DX-JY|  楼主 | 2015-7-5 18:43 | 只看该作者
沉得好快呀!
个人签名:晴天响霹雳,平地一声雷。
245
