[技术问题解答] ubuntu12.04 安装ltib一直出错
1280|0
 楼主| feiyashan 发表于 2015-7-17 15:14 | 显示全部楼层 |阅读模式
用ubuntu12.04安装ltib出现如下错误:
ss@ubuntu:~/shanyf/P4080-PCIE-SDK-1.0-05-03-2012/ltib-e500mc-20110415$ ./ltib
Installing host support packages.
This only needs to be done once per host, but may take up to
an hour to complete ...
If an error occurs, a log file with the full output may be found in:
/home/shanyf/shanyf/P4080-PCIE-SDK-1.0-05-03-2012/ltib-e500mc-20110415/host_config.log
Exiting on error or interrupt
Please see >> /home/shanyf/shanyf/P4080-PCIE-SDK-1.0-05-03-2012/ltib-e500mc-20110415/host_config.log for details
打开错误中制定的文件/host_config显示如下
rpmdb: --force-debian: unknown option
Died at ./ltib line 2339.
traceback:
main::setup_rpmdb:2339
  main::check_rpm_setup:2403
   main::host_checks:1424
    main:543
Started: Thu Jul 16 18:54:40 2015
Ended:   Thu Jul 16 18:54:41 2015
Elapsed: 1 seconds
Build Failed
请问大神怎么解决
