[ZLG-ARM] t6963怎样调用其内部字符啊?
2221|0
 楼主| jstu023123 发表于 2008-5-21 16:50 | 显示全部楼层 |阅读模式
&nbsp;&nbsp;现在需要使用t6963内部提供的字符,不知道怎么调用了,以前都自己做的字库。。。就是在选择CGROM方式后该怎么处理可以把字符显示出来<br />初始化配置如下:<br />#define&nbsp;MAX_RAM_LEN&nbsp;&nbsp;&nbsp;(UINT16)(MAX_X_DOT_NUMS*MAX_Y_DOT_NUMS/8L)&nbsp;//一页显存字节数据(&nbsp;3840)<br />#define&nbsp;TEXT_LCD_RAM&nbsp;((UINT16)(4*MAX_RAM_LEN))&nbsp;&nbsp;//文本显示地址<br /><br />&nbsp;void&nbsp;LCD_HardwareInit(void)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Write_Com1(0x90);&nbsp;&nbsp;//先关显示,防止开机时图像杂乱<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Write_Com3(&nbsp;0x00,0x00,0x42&nbsp;);&nbsp;//设置图形显示区域首地址&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Write_Com3((UINT8)TEXT_LCD_RAM,(UINT8)(TEXT_LCD_RAM&gt&gt8),0x40&nbsp;);&nbsp;//设置文本显示区域首地址(设置在第4页)<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Write_Com3(&nbsp;30,&nbsp;0x00,&nbsp;0x43&nbsp;);&nbsp;//设置图形显示区域宽度&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Write_Com3(&nbsp;30,&nbsp;0x00,&nbsp;0x41&nbsp;);&nbsp;//设置文本显示区域宽度&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Write_Com1(0xa1);&nbsp;//设置光标形状&nbsp;cursor&nbsp;size&nbsp;8x1<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Write_Com1(0x81);&nbsp;//设置显示方式:&nbsp;CGROM方式&nbsp;文本图形&nbsp;&quot;异或&quot;(支持光标)&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;sVram_Head_Add=TEXT_LCD_RAM;<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Cls(&nbsp;);&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;//清文本显示区<br />&nbsp;&nbsp;&nbsp;&nbsp;sVram_Head_Add=0;&nbsp;&nbsp;&nbsp;&nbsp;//当前页0<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Cls(&nbsp;);<br />&nbsp;&nbsp;&nbsp;&nbsp;LCD_Write_Com1(0x9d);&nbsp;//设置显示开关:&nbsp;1001&nbsp;1100&nbsp;图形,开显示<br /><br />}<br />
