[Atmel] 这个三维打印的机器人可以在密闭空间内导航
826|4
 楼主| ddllxxrr 发表于 2015-8-24 20:33 | 显示全部楼层 |阅读模式
When disaster strikes, one of the biggest problems challenges that rescue teams encounter is locating and reaching survivors amid the rubble. Unfortunately, there are times even with today’s advanced technologies where humans are unable to slip into a tight space and extract an individual. But what if there was a robotic device that could? That is the idea behind a recent project by Juan Cristóbal Zagal.
Developed in collaboration with researchers from the University of Chile and University of Akron, OctaWorm is a 3D-printed octahedral robot that is capable of morphing its body to squeeze through holes, gaps and debris. The latest version, now the third prototype, is comprised mostly of 3D-printed parts and some aluminum rods for enhanced durability. It employs pneumatic-driven servo motors for movement and is operated via a wired controller, though the team hopes to make this wireless in the near future.
Aside from that, the robot is equipped with an Arduino board, an Arduino-compatible shield to controls the relays and three pneumatic solenoid valves. Since the OctaWorm is pneumatically driven, Zagal used high-quality rapid pneumatic connectors and plastic tubing to attach it to the controller.
The robot also features 3D-printed ball joints, which enable it to grip onto and traverse through any type of terrain. These rubbery balls are tasked with handling the deformation motion, and allow it to assume a variety of shapes and configurations as it slips into a crack or crevice.
“The current version of the robot is capable of traveling inside a pipe. It is also capable of dealing with changes on the internal diameter of the pipe. The functional symmetry of the robot allows it to travel along T, L and Y joints in pipelines. Traditional in-pipe robots have many problems for dealing with these types of junctions. In contrast the deformable octahedral robotcan simply squeeze into junctions,” Zagal tells 3DPrint.com.
The goal of the project was to develop a new way to use robotic motion to access and navigate confined spaces typically found in disaster situations, as well as pipes and air ducts. In the future, Zagal envisions an even tinier version that could be used for medical applications, such as going through blood vessels.
Until then, you can watch the OctaWorm in action below!
kafeng 发表于 2015-8-24 20:47 | 显示全部楼层
哎呀,英文不好,又吃力了~~
 楼主| ddllxxrr 发表于 2015-8-24 20:58 | 显示全部楼层
哎呀,英文不好,又吃力了~~
呵呵,慢慢看
毁灭2012 发表于 2015-8-31 22:40 | 显示全部楼层
这个是三维打印的机器人啊,怎么看着不像呀 哈哈、。
黑夜的风 发表于 2015-8-31 22:44 | 显示全部楼层
3D机器人好丑,没想象中的霸气
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
