STM32外扩RAM是多少位的?
6045|7
 楼主| colaring 发表于 2008-7-26 00:36 | 显示全部楼层 |阅读模式
听说外扩RAM是8位的?不会吧
香水城 发表于 2008-7-26 01:03 | 显示全部楼层
好像很多人不习惯看手册
楼主不要道听途说,你可以自己在下面这张表中数数有多少位。这张表是从最新的STM32F103xC/D/E数据手册中截下来的(第32、33页)。
相关链接:http://www.st.com/stonline/products/literature/ds/14611.pdf
computer00 发表于 2008-7-26 01:52 | 显示全部楼层
哈哈~~~是16位的~~~不过似乎没看到高低字节选通的脚哦……
应该有这功能的吧...
formatC 发表于 2008-7-26 02:29 | 显示全部楼层
外部总线似乎不能DMA
香水城 发表于 2008-7-26 08:47 | 显示全部楼层
【新应用笔记】使用高容量STM32F10xxx连接外部存储器
内有FSMC与外部存储器接口的参考线路和时序。
AN2784 - Using the high-density STM32F10xxx FSMC peripheral to drive external memories
Introduction
This application note describes how to use the High-density STM32F10xxx FSMC (flexible static memory controller) peripheral to drive a set of external memories. To that aim, it gives an overview of the STM32F10xxx FSMC controller. Then it provides memory interfacing examples that include the typical FSMC configuration, the timing computation method and the hardware connection.
This application note is based on memories mounted on the STM3210E-EVAL, which is the evaluation board for High-density STM32F10xxx devices. The used memories are a 16-bit asynchronous NOR Flash memory, an 8-bit NAND Flash memory and a 16-bit asynchronous SRAM.
kl818bc 发表于 2008-7-26 08:57 | 显示全部楼层
RE 3楼:computer00
NBL0 和 NBL1 就是你要的管脚
computer00 发表于 2008-7-26 11:41 | 显示全部楼层
哦,原来如此,总感觉ST的命名规则跟别的不大一样,晕……
lianshumou 发表于 2008-7-26 16:44 | 显示全部楼层
外部的是可以DMA的!
