有谁可以提供个中断主方式的SPI 1 程序让我参考一下最好不使用库,搞了几天了还是只能够设置完了后进一次中断,
//=================================================================== // //=================================================================== void STM32_SPI_Configuration(void) { //SPI_InitTypeDef SPI_InitStructure; //GPIO_InitTypeDef GPIO_InitStructure; /* Enable SPI1 and GPIOA clocks */ // RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); STM32_Rcc_Regs->apb2enr.all |= RCC_SPI1EN; // 时钟使能 /* Configure SPI1 pins: NSS, SCK, MISO and MOSI */ //GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7; //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //GPIO_Init(GPIOA, &GPIO_InitStructure); STM32_Gpioa_Regs->crl.bit.CNF5 = Output_Af_push_pull; STM32_Gpioa_Regs->crl.bit.MODE5 = Output_Mode_50mhz;
STM32_Gpioa_Regs->crl.bit.CNF6 = Output_Af_push_pull; STM32_Gpioa_Regs->crl.bit.MODE6 = Output_Mode_50mhz; STM32_Gpioa_Regs->crl.bit.CNF7 = Output_Af_push_pull; STM32_Gpioa_Regs->crl.bit.MODE7 = Output_Mode_50mhz;
/* Configure PA.4 as Output push-pull, used as Flash Chip select */ //GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //GPIO_Init(GPIOA, &GPIO_InitStructure); STM32_Gpioa_Regs->crl.bit.CNF4 = Output_push_pull; STM32_Gpioa_Regs->crl.bit.MODE4 = Output_Mode_50mhz;
/* Deselect the FLASH: Chip Select high */ //GPIOA->BSRR = GPIO_Pin_4; STM32_Gpioa_Regs->bsrr.bit.BS4 = 1;// 置位
/* SPI2 configuration */ //SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8; //SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //SPI_InitStructure.SPI_CRCPolynomial = 7; //SPI_Init(SPI1, &SPI_InitStructure); STM32_Spi1_Regs->cr1.bit.BR = 2; // 72mhz/8=9mhz 010=Fpclk/8 STM32_Spi1_Regs->cr1.bit.CPHA = 1; // 1: 数据采样从第二个时钟边沿开始 STM32_Spi1_Regs->cr1.bit.CPOL = 1; // 1: 空闲状态时,SCK保持高电平 STM32_Spi1_Regs->cr1.bit.DFF = 0; // 0:使用8位数据帧格式进行发送/接收 STM32_Spi1_Regs->cr1.bit.LSBFIRST = 0; // 0:先发送MSB STM32_Spi1_Regs->cr1.bit.MSTR = 1; // 1:配置为主设备 STM32_Spi1_Regs->cr1.bit.SSM = 1; // 1:启用软件从设备管理。 STM32_Spi1_Regs->cr1.bit.BIDIMODE = 0; //0:选择“双线双向”模式 /* Enable SPI1 TXE interrupt */ //SPI_I2S_ITConfig(SPI1, SPI_I2S_IT_TXE, ENABLE); STM32_Spi1_Regs->cr2.bit.TXEIE = 1; /* Enable SPI1 RXNE interrupt */ //SPI_I2S_ITConfig(SPI1, SPI_I2S_IT_RXNE, ENABLE); //STM32_Spi1_Regs->cr2.bit.RNXEIE = 1; /* Enable SPI1 */ //SPI_Cmd(SPI1, ENABLE); STM32_Spi1_Regs->cr1.bit.SPE = 1; //1:开启SPI设备 /* Configure and enable SPI1 interrupt -------------------------------------*/ //NVIC_InitStructure.NVIC_IRQChannel = SPI1_IRQChannel; //NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //NVIC_Init(&NVIC_InitStructure); /* enabling interrupt 设置SPI1中断优先级,和关中断*/ STM32_Nvic_Regs->Priority[35].all = 0x50; STM32_Nvic_Regs->Enable[1].bit.INT3 = 1; // 37 (35-32=3) 44 可设置 SPI1 SPI1全局中断 0x0000_00cc }//end sub
/******************************************************************************* * Function Name : SPI1_IRQHandler * Description : This function handles SPI1 global interrupt request. * Input : None * Output : None * Return : None *******************************************************************************/ void SPI1_IRQHandler(void) { // wwd mask //if (SPI_I2S_GetITStatus(SPI1, SPI_I2S_IT_TXE) != RESET) //{ // /* Send SPI1 data */ // SPI_I2S_SendData(SPI1, SPI1_Buffer_Tx[TxIdx++]); // // /* Disable SPI1 TXE interrupt */ // if (TxIdx == BufferSize) // { // SPI_I2S_ITConfig(SPI1, SPI_I2S_IT_TXE,DISABLE); // } //} // wwd mask end
// wwd mask if( STM32_Spi1_Regs->sr.bit.TXE != 0) { /* Send SPI1 data */ //STM32_Spi1_Regs->dr.all = SPI1_Buffer_Tx[TxIdx++]; STM32_Spi1_Regs->dr.all = 0x55;
/* Disable SPI1 TXE interrupt */ //if (TxIdx == BufferSize) //{ // //SPI_I2S_ITConfig(SPI1, SPI_I2S_IT_TXE, DISABLE); // STM32_Spi1_Regs->cr2.bit.TXEIE = 0; //} } // wwd mask end } |
