STM32入门例程,595串行8位数码管源程序
8878|4
 楼主| sujianli 发表于 2008-5-22 03:02 | 显示全部楼层 |阅读模式
STM32,通过595串行,驱动8位数码管显示“12345678”源程序
在Mini-STM32学习板上上调试通过
(Mini-STM32学习板介绍:http://www.u-easytech.com/chinese/product.asp?id=96)
相关链接:http://www.u-easytech.com/upfiles/八位数码管12345678.rar
hotpower 发表于 2008-5-23 07:20 | 显示全部楼层
沙发~~~
 楼主| sujianli 发表于 2008-5-24 17:18 | 显示全部楼层
干脆贴个驱动这部分的程序。RAR里是完整的工程
//GPIO define
//Design by :Tan/yicheng
//pctanyicheng@163.com
//u-easytech@163.com
//重庆优易特电子
// COPYRIGHT:重庆优易特电子
//http://www.u-easytech.com/chinese/
//FUNCTION:用595完成八位数码管显示
#include <stm32f10x_lib.h>              /* STM32F10x Library Definitions      */
#include "UET_GPIO.h"
//unsigned char  seg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0x8c,0xc1,0xce,0x91,0x89,0xc7,0xff};
                        0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
                        0x77,0x7c,0x39,0x5e,0x79,0x71,0x73,0x78,0x5c,0x54,
                        0x40,0x81,0x88,0x3e,0x70,0x00
                        //0,1,2,3,4,5,6,7,8,9,
                          //A,b,C,d,E,F,P,t,o,n,
                         //-,~,_,U,r,SP,
//unsigned char  DAT[]={0x7f,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};           //位选择
unsigned char BitSelect_Code[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};   //因为ULN2803驱动反相,所以位码要用共阳极的位码
        //COM1 COM2 COM3 COM4      COM5 COM6 COM7 COM8
        // B0   B1  B2     B3    B4   B5   B6   B7
unsigned  char  Disp_buffer[]={0,1,2,3,4,5,6,7};                       //段缓冲区
unsigned  char      Bit_NO=0       ;                        //      选择第Bit_NO位数码管
unsigned  char      Buffer_NO=0;                           //     缓冲区的第Buffer_NO
u32 LED_DATA=01234567;
 #define SER(x)             GPIOA->ODR=(GPIOA->ODR&~GPIO_Pin_7)          | (x ? GPIO_Pin_7 : 0)
 #define SCK(x)              GPIOA->ODR=(GPIOA->ODR&~GPIO_Pin_5)          | (x ? GPIO_Pin_5 : 0)
 #define RCK(x)              GPIOA->ODR=(GPIOA->ODR&~GPIO_Pin_6)          | (x ? GPIO_Pin_6 : 0)
* Function Name  :  void WR_595(unsigned char segdata)
* Description    : 595串行输入
* Input          : 段码
* Output         : None
* Return         : None
 void WR_595(unsigned char segdata) //输入一字节数码管数据进595
  unsigned char i,temp;
  temp=segdata;
  for(i=0;i<8;i++)           //循环移入8位数据,
  SCK(0);
  if(temp&0x80)          // 取数码的最高位
   SER(1);
   else
   SER(0);
  temp=temp<<1;
  SCK(1);     //上升沿把一位数据移入595
* Function Name  : void OUT_595(void)
* Description    : 595锁存输出
* Input          : 段码
* Output         : None
* Return         : None
void OUT_595(void)      //上升沿将数据送到输出锁存器
{  unsigned i;
    RCK(0);
 for(i=0;i<10;i++)    ;
    RCK(1);
    RCK(0);
* Function Name  : void LED_Brush(u32 LED_DATA)
* Description    : 数码管缓冲数据刷新
* Input          : u32 LED_DATA
* Output         : None
* Return         : None
  Disp_buffer[0]=LED_DATA/1000%10;
  Disp_buffer[1]=LED_DATA/100%10;
  Disp_buffer[2]=LED_DATA/10%10;
  Disp_buffer[3]=LED_DATA%10;
  Disp_buffer[4]=LED_DATA/10000000;
  Disp_buffer[5]=LED_DATA/1000000%10;
  Disp_buffer[6]=LED_DATA/100000%10;
  Disp_buffer[7]=LED_DATA/10000%10;
* Function Name  : void Display(void)
* Description    : 显示
* Input          : None
* Output         : None
* Return         : None
void Display(void)
     LED_Brush(12345678);//调用显示函数
     WR_595(BitSelect_Code[Bit_NO]);            // 位码
     WR_595(seg[Disp_buffer][Buffer_NO]]);    //段码
     OUT_595();
     Bit_NO++;
     Buffer_NO++;
     if( Buffer_NO>7) Buffer_NO=0;
     if(Bit_NO>7)Bit_NO=0;
化雨眠66 发表于 2012-10-18 21:12 | 显示全部楼层
伊泽瑞拉 发表于 2014-9-1 15:42 | 显示全部楼层
楼主   链接失效了    求程序
