我的SRT912中断异常,连续下降沿中断,会出现死机,连续上升沿中断会出现部分中断丢失 我的中断配制程序:
void SetRFEdage(int fall) { /*DCLK(P5.2) pin configuration */ GPIO_InitTypeDef GPIO_InitStruct; WIU_InitTypeDef WIU_InitStructure;
if(fall==1) { //Set DCLK INT in falling edge WIU_ClearITPendingBit(WIU_Line10 ); WIU_InitStructure.WIU_Mode = WIU_Mode_Interrupt ; WIU_InitStructure.WIU_Line = WIU_Line10 ; WIU_InitStructure.WIU_TriggerEdge = WIU_FallingEdge ; WIU_Init(&WIU_InitStructure);
/* Configure the External interrupt group 3 priority */ VIC_Config(EXTIT1_ITLine, VIC_IRQ, 11);
/* Enable the External interrupt group 3 */ VIC_ITCmd(EXTIT1_ITLine, ENABLE); SCU_WakeUpLineConfig(10);
//Set DIO--P2.7 as output GPIO_StructInit(&GPIO_InitStruct); GPIO_InitStruct.GPIO_Direction = GPIO_PinOutput; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_7; GPIO_InitStruct.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStruct.GPIO_Alternate = GPIO_OutputAlt1; GPIO_Init (GPIO2, &GPIO_InitStruct); } else { //set DCLK INT on rising edge WIU_ClearITPendingBit(WIU_Line10 ); WIU_InitStructure.WIU_Mode = WIU_Mode_Interrupt ; WIU_InitStructure.WIU_Line = WIU_Line10 ; WIU_InitStructure.WIU_TriggerEdge = WIU_RisingEdge ; WIU_Init(&WIU_InitStructure);
/* Configure the External interrupt group 3 priority */ VIC_Config(EXTIT1_ITLine, VIC_IRQ, 11); /* Enable the External interrupt group 3 */ VIC_ITCmd(EXTIT1_ITLine, ENABLE); SCU_WakeUpLineConfig(10);
//Set DIO--P2.7 as input GPIO_StructInit(&GPIO_InitStruct); GPIO_InitStruct.GPIO_Direction = GPIO_PinInput; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_7; GPIO_InitStruct.GPIO_Type = GPIO_Type_PushPull ; GPIO_Init (GPIO2, &GPIO_InitStruct); }
void EXTIT1_IRQHandler(void) {
InterruptHandler(); WIU_ClearFlag(WIU_Line10); } |
