ADC功耗问题
2851|4
 楼主| kingjiang 发表于 2008-12-25 15:42 | 显示全部楼层 |阅读模式
请教各位大虾:
             我从datasheet(101ZE)来看,里面有提到每加一个ADC就多0.8mA的电流消耗.那么这个功耗是指什么ADCCLK频率下的功耗?ADCCLK频率与功耗有什么关系?
            谢谢!
香水城 发表于 2008-12-25 17:26 | 显示全部楼层
你看得是哪一页?
请看下面这页,在表格下方有测试条件的说明:
 楼主| kingjiang 发表于 2008-12-25 18:10 | 显示全部楼层
 楼主| kingjiang 发表于 2008-12-25 18:12 | 显示全部楼层
上表的测试条件
The MCU is placed under the following conditions:
● All I/O pins are in input mode with a static value at VDD or VSS (no load)
● All peripherals are disabled except if it is explicitly mentioned
● The Flash access time is adjusted to fHCLK frequency (0 wait state from 0 to 24 MHz, 1
wait state from 24 to 36 MHz)
● Prefetch is on (reminder: this bit must be set before clock setting and bus prescaling)
● When the peripherals are enabled fPCLK1 = fHCLK/4, fPCLK2 = fHCLK/2, fADCCLK =
fPCLK2/4
The parameters given in Table 15 are derived from tests performed under the ambient
temperature and VDD supply voltage conditions summarized in Table 8.
香水城 发表于 2008-12-25 18:36 | 显示全部楼层
请看一下手册的最上面,每页都有该手册对应的芯片型号
我没有找到你贴出的这部分是从哪个型号、哪个版本的手册中截出来的,请下载最新的数据手册。
你问的是STM32F101ZET6,请下载这个链接的文件,在与你贴出的图对应的表上方有测试条件的说明:
