| 紧跟上贴
 FilesCOSMICCXSTM8Libcrtsi0.sm8
 _number_UP                  00000049   defined in Debugmain.o section .ubsct
 _overtime_counter           00000043   defined in Debugmain.o section .ubsct
 _persist_arlam              00005c:5   defined in Debugmain.o section .bit, initialized
 _pulse_H                    00000023   defined in Debugmain.o section .ubsct
 _pulse_L                    00000022   defined in Debugmain.o section .ubsct
 _rc_bit                     00000024   defined in Debugmain.o section .ubsct
 _read                       00000000   defined in Debugmain.o section .bsct, initialized
 _read_one_byte              0000818c   defined in Debugmain.o section .text
 _receive_alarm              00005e:2   defined in Debugmain.o section .bit, initialized
 _receiver_end               00005c:3   defined in Debugmain.o section .bit, initialized
 _receiver_high_sign         00005c:1   defined in Debugmain.o section .bit, initialized
 _receiver_low_sign          00005c:2   defined in Debugmain.o section .bit, initialized
 _redressal_sign             00005f:2   defined in Debugmain.o section .bit, initialized
 _repeat_sign                00005f:1   defined in Debugmain.o section .bit, initialized
 _rf_sign                    00005a:3   defined in Debugmain.o section .bit, initialized
 _run_time                   00009031   defined in Debugmain.o section .text
 _rx_temp_data               00000021   defined in Debugmain.o section .ubsct
 _sec                        00005b:4   defined in Debugmain.o section .bit, initialized
 _select_coder               00008658   defined in Debugmain.o section .text
 _showCounter                0000003a   defined in Debugmain.o section .ubsct
 _show_9                     00005d:4   defined in Debugmain.o section .bit, initialized
 _simulate_clock             00008fc8   defined in Debugmain.o section .text
 _sound_end                  00005b:2   defined in Debugmain.o section .bit, initialized
 _sound_frequency            0000003f   defined in Debugmain.o section .ubsct
 _start_dw_eeprom_sign       00005a:7   defined in Debugmain.o section .bit, initialized
 _start_receive_count        00000045   defined in Debugmain.o section .ubsct
 _state_sign                 00005e:3   defined in Debugmain.o section .bit, initialized
 _study_show                 00005d:6   defined in Debugmain.o section .bit, initialized
 _study_show_temp            00005d:5   defined in Debugmain.o section .bit, initialized
 _study_sign                 00005f:3   defined in Debugmain.o section .bit, initialized
 _system_ulock               000096fd   defined in Debugmain.o section .text
 _table                      00008d4c   defined in Debugmain.o section .text
 _temp1                      00005e:6   defined in Debugmain.o section .bit, initialized
 _time_3ms                   0000003d   defined in Debugmain.o section .ubsct
 _time_5                     00000036   defined in Debugmain.o section .ubsct
 _time_6                     00000038   defined in Debugmain.o section .ubsct
 _transmit_IO                005006:2   defined in Debugmain.o
 _transmit_alarm_sign        00005a:2   defined in Debugmain.o section .bit, initialized
 _transmit_dalay_time        00000004   defined in Debugmain.o section .bsct, initialized
 _transmit_delay_counter     0000004a   defined in Debugmain.o section .ubsct
 _transmit_delay_sign        00005a:1   defined in Debugmain.o section .bit, initialized
 _tx_size                    00000025   defined in Debugmain.o section .ubsct
 _uart_data_length           00000046   defined in Debugmain.o section .ubsct
 _uart_dw_end_sign           00005a:6   defined in Debugmain.o section .bit, initialized
 _uart_length                00005b:1   defined in Debugmain.o section .bit, initialized
 _uart_start                 00005c:4   defined in Debugmain.o section .bit, initialized
 _uart_temp_sign             00005a:5   defined in Debugmain.o section .bit, initialized
 _ulock                      00005a:4   defined in Debugmain.o section .bit, initialized
 _wireless_in                005006:4   defined in Debugmain.o
 _wireless_out               005005:3   defined in Debugmain.o
 _wireless_switch            00005c:0   defined in Debugmain.o section .bit, initialized
 _wireless_switch1           00005a:0   defined in Debugmain.o section .bit, initialized
 _wireless_tx_test           00008cbd   defined in Debugmain.o section .text
 _wr_eeprom_size             00000048   defined in Debugmain.o section .ubsct
 _write                      00000002   defined in Debugmain.o section .bsct, initialized
 _write_eeprom_control       0000950b   defined in Debugmain.o section .text
 _write_one_byte             00008116   defined in Debugmain.o section .text
 _zen                        0000000a   defined in Debugmain.o section .ubsct
 _zen_alarm_show_counter     00000032   defined in Debugmain.o section .ubsct
 _zen_counter                0000001d   defined in Debugmain.o section .ubsct
 _zen_counter_1              0000001b   defined in Debugmain.o section .ubsct
 _zen_show_cycle             0000001a   defined in Debugmain.o section .ubsct
 c_imul                      00009783   defined in (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)imul.o section .text
 used in Debugmain.o
 c_lcmp                      000097a4   defined in (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)lcmp.o section .text
 used in Debugmain.o
 c_lgadc                     000097c4   defined in (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)lgadc.o section .text
 used in Debugmain.o
 c_lreg                      00000050   defined in (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)lreg.o section .ubsct
 used in (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)lcmp.o
 (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)ltor.o
 (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)utolx.o
 c_ltor                      000097d4   defined in (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)ltor.o section .text
 used in Debugmain.o
 c_uitolx                    000097e6   defined in (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)utolx.o section .text
 used in Debugmain.o
 c_x                         00000054   defined in (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)xreg.o section .ubsct
 used in F:Program FilesCOSMICCXSTM8Libcrtsi0.sm8
 Debugmain.o
 c_y                         00000057   defined in (F:Program FilesCOSMICCXSTM8Liblibm0.sm8)yreg.o section .ubsct
 Debugmain.o
 f_ADC1_IRQHandler           00008477   defined in Debugmain.o section .text
 used in Debugstm8_interrupt_vector.o
 f_NonHandledInterrupt       000097ed   defined in Debugstm8_interrupt_vector.o section .text
 f_TIM2_UPD_OVF_IRQHandler   000083cc   defined in Debugmain.o section .text
 f_TIM3_UPD_OVF_IRQHandler   00008448   defined in Debugmain.o section .text
 f_TIM4_UPD_OVF_IRQHandler   000083a1   defined in Debugmain.o section .text
 f_UART2_RX_IRQHandler       00008501   defined in Debugmain.o section .text
 f_UART2_TX_IRQHandler       000084d8   defined in Debugmain.o section .text
