<font color=#000000>执行写命令OK,</font>例如我W_cmd(0x85); 光标会跑到第一行第五列的位置并闪烁.<br />但是当我执行写数据指令把要显示的内容写入的时候,屏幕就什么也没有了.<br />我怀疑是W_data();有问题,可是我试了把 LCD_DATA=lcddata;放在LCD_EN=1;前面,也不行,而且我看别人的demo程序时序也是这样的,实在找不出问题了.<br />以前没有搞过LCD,请高手帮忙看看,<br />/*-------------------------------------------------------------<br /><br />-------------------------------------------------------------*/<br />#include "REG52.H"<br /> <br />#define uchar unsigned char <br /><br /><br />/*-------------------------------------------------------------<br />sbit分别定义CPU 管脚对应的硬件连接<br />-------------------------------------------------------------*/<br />sfr LCD_DATA = 0xA0;<br /><br />sbit LCD_EN = 0xB3;//------P3.3 Enable Pin<br />sbit LCD_RS = 0xB4;//------P3.4 RS pin<br />sbit LCD_RW = 0xB5;//------P3.5 R/W pin<br /><br />sbit led0 = 0x80;//------LED, for debug<br />sbit led1 = 0x82;//------LED, for debug<br />sbit led2 = 0x84;//------LED, for debug<br />sbit led3 = 0x86;//------LED, for debug<br />sbit bflag=P2^7; //------busy bit<br /><br /><br />LCD_busy(void); //判断LCD BUSY<br />void W_cmd(uchar); //写命令<br />void R_data(void); //读数据<br />void W_data(uchar); //写数据<br />void Delay_xMs(unsigned int x);//延时;<br /><br /><br />LCD_busy(void) //----判断LCD BUSY<br />{<br />unsigned char Lcdbusy;<br /> LCD_EN=0; //clear enable<br /> led0=0;<br /> Delay_xMs(3);<br /> LCD_RS=0; //clear RS<br /> led1=0;<br /> Delay_xMs(3);<br /> LCD_RW=1; //set R/W<br /> led2=1;<br /> Delay_xMs(3);<br /> LCD_EN=1; //set enable<br /> led0=1;<br /> Delay_xMs(3);<br /> Lcdbusy=P2; //读P2口,取得BF状态 <br /> while( bflag==1) <br /> { Lcdbusy=P2;}<br /> LCD_EN=0; //clear EN<br /> led0=0;<br /><br />}<br />void W_cmd(uchar lcdcmd) //---写命令<br />{ <br /> LCD_busy(); //判断BUSY<br /> LCD_EN=0; //clear EN<br /> led0=0;<br /> Delay_xMs(3);<br /> LCD_RS=0; //clear RS<br /> led1=0;<br /> Delay_xMs(3);<br /> LCD_RW=0; //clear RW<br /> led2=0;<br /> Delay_xMs(3);<br /> LCD_EN=1; //set EN<br /> led0=1;<br /> Delay_xMs(3);<br /> LCD_DATA=lcdcmd; //send command to LCD<br /> LCD_EN=0; //clear EN<br /> led1=0;<br /> Delay_xMs(128);<br />}<br /><br />void W_data(uchar lcddata) //--写数据到LCD<br />{<br /> LCD_busy(); //判断BUSY<br /> LCD_EN=0; //clear EN<br /> led0=0;<br /> Delay_xMs(3);<br /> LCD_RS=1; //set RS<br /> led1=1;<br /> Delay_xMs(3);<br /> LCD_RW=0; //clear RW<br /> led2=0;<br /> Delay_xMs(3);<br /> LCD_EN=1; //set EN<br /> led0=1;<br /> Delay_xMs(3);<br /> LCD_DATA=lcddata; //send data to LCD<br /><br /> LCD_EN=0; //clear EN<br /> led0=0;<br /> Delay_xMs(128);<br />}<br /><br /><br /><br /><br />/*------------------------------------------------<br />功能:显示码.<br />-------------------------------------------------*/<br />unsigned char code LCD_Show[]={0x50,0xf5,0x68,0x4a,0x47,0xc2,0xc0,0x5b,0x40,0x42,0x41,0xc4,0xf0,0x4c,0xe0,0xe1,0xff};<br /><br /><br />/*-------------------------------------------------<br />功能:1MS延时子程序<br />-------------------------------------------------*/<br />void Delay_xMs(unsigned int x)<br />{<br /> unsigned int i,j;<br /> for( i =0;i < x;i++ )<br /> {<br /> for( j =0;j<500;j++ );<br /> }<br />}<br /><br />/*-------------------------------------------------<br />主程序<br />--------------------------*/<br />void main()<br />{ <br /><br /> uchar i;<br /> LCD_EN=0;<br /> led0=0;<br /> LCD_RW=0;<br /> led2=0;<br /><br />// led0=0;<br /> W_cmd(0x38);//显示模式设置,这个命令的格式为:001,DL,N,F,-,-<br /> ; ------------------------------------------------请看第6条命令的说明,因这是一个16字符<br /> ;--------------------------------------------------2行的模组,用并行传输,因此将DL设定为1,将N设定<br /> ;--------------------------------------------------为1表示有两行,将F设定为0,表示用5X8的点的字符<br />// led1=0;<br /> W_cmd(0x01);//清屏<br /> W_cmd(0x0E);;-----------------显示,光标,闪动控制,这个命令的格式为:00001,D,C,B<br /> ;--------------------------------------------------D为1,表示显示开,C为0表示光标关,B为0表示闪动关<br /> W_cmd(0x80);//设定首行地址<br /><br /> W_data(0x55);//写入要显示的内容--------<b><font color=#000000>问题就在这行执行以后</font></b><br /><br /><br />// led2=0;<br /> while(1); <br /><br /> |
