[Actel FPGA] 模拟部分仿真
1987|1
 楼主| 天交 发表于 2008-2-23 17:59 | 显示全部楼层 |阅读模式
 楼主| 天交 发表于 2008-2-23 18:00 | 显示全部楼层
# Error : When using the Voltage Prescaler, the AV Prescaler Opamp mode needs to be powered up, and the AV direct analog input switch needs to be switched OFF - AV  2, at time 60466.0
