发送数据:
void SendOneByte(u8 Byte)
u8 i=8,tmp;
TXD_low(); //发送起始位
delay_us(104);
//发送8位数据
for(i=0;i<8;i++)
tmp = (Byte >> i) & 0x01; //低位在前
if(tmp == 0)
TXD_low();
delay_us(104); //0
else
TXD_high();
delay_us(104); //1
// while(i--)
// MNUSART_TXD = (Byte&0x01); //先传低位
// delay_us(104);
// Byte = Byte>>1;
// //无校验位
// MNUSART_TXD=1;//发送结束位
// delay_us(104);
TXD_high();
delay_us(104);
void SendBytes(u8 *str,u8 len) //发送数组最好用这个,也可发送字符串
u16 i;
for(i=0;i<len;i++)
SendOneByte(str[i]);
void SendStr(u8 *str) //发送字符串,发送数组如果带0x00就中断发送了
while(*str)
SendOneByte(*str++);
接收用的外部中断:
void EXTIX_Init(void)
EXTI_InitTypeDef EXTI_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9 端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz
GPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化GPIOB.5
GPIO_SetBits(GPIOA,GPIO_Pin_9);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //浮空输入
GPIO_SetBits(GPIOA,GPIO_Pin_10);
//GPIOA.10 中断线以及中断初始化配置 下降沿触发
GPIO_EXTILineConfig(GPIO_PortSourceGPIOA,GPIO_PinSource10);
EXTI_InitStructure.EXTI_Line=EXTI_Line10;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure); //根据EXTI_InitStruct中指定的参数初始化外设EXTI寄存器
NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void EXTI15_10_IRQHandler(void)
u8 i=9;
if(EXTI_GetITStatus(EXTI_Line10) != RESET)
/* Disable the Selected IRQ Channels -------------------------------------*/
NVIC->ICER[EXTI15_10_IRQn >> 0x05] =
(uint32_t)0x01 << (EXTI15_10_IRQn & (uint8_t)0x1F);
EXTI_ClearITPendingBit(EXTI_Line10);
delay_us(30);
while(i--)
tmp >>=1;
if(GPIOA->IDR&0x0400) tmp |=0x80;
delay_us(104);
if((USART_RX_STA&0x8000)==0)
if(USART_RX_STA&0x4000)
if(tmp!=0x0a) USART_RX_STA=0;
else USART_RX_STA |=0x8000;
else
if(tmp==0x0d) USART_RX_STA|=0x4000;
else
USART_RX_BUF[USART_RX_STA&0X3FFF]=tmp ;
USART_RX_STA++;
if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收数据错误,重新开始接收
NVIC->ISER[EXTI15_10_IRQn >> 0x05] =
主函数:
int main(void)
u8 len;
u8 hello[]={0x5a,0xa5,0x00,0x00,0x01};
delay_init();
EXTIX_Init();
//测试 发送一个字节
SendOneByte(0x00);
SendOneByte(0x01);
SendOneByte(0x02);
//测试发送数组
SendBytes(hello,5);
//测试发送字符串
// SendBytes("hello word",11);
// SendStr("德玛西亚");
while(1)
if(USART_RX_STA&0x8000)
printf("\r\n您发送的消息为:\r\n\r\n");
len=USART_RX_STA&0x3fff;//得到此次接收到的数据长度
SendBytes(USART_RX_BUF,len);
//也可以用下面的发送
// SendStr(USART_RX_BUF);
// for(len=0;len<200;len++)
// USART_RX_BUF[len]=0;
printf("\r\n\r\n");//插入换行
USART_RX_STA=0;
