哪位仁兄知道,为什么iar5.0里面RTOS范例居然不能下载运行
5480|3
 楼主| tomzxq 发表于 2009-8-4 18:07 | 显示全部楼层 |阅读模式
今天想学习一下rtos,于是运行C:\Program Files\IAR Systems\Embedded Workbench 5.0 Evaluation\ARM\PowerPac\BoardSupport\ST\STM32的范例,发现居然不能下载运行,没觉得哪里有问题?哪位大侠帮忙一下。
lpf336 发表于 2009-8-4 18:10 | 显示全部楼层
详细描述一下,你安装的软件有没有问题?
 楼主| tomzxq 发表于 2009-8-5 09:30 | 显示全部楼层
编译没有问题,但是下载仿真的时候出现错误
Wed Aug 05 09:14:00 2009: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 5.0 Evaluation\ARM\config\flashloader\ST\FlashSTM32F10**.mac
Wed Aug 05 09:14:00 2009: DLL version: V4.6b, compiled Jun 12 2009 13:25:42
Wed Aug 05 09:14:00 2009: Firmware: J-Link ARM V6 compiled May 27 2009 17:26:00
Wed Aug 05 09:14:00 2009: JTAG speed is initially set to: 5 kHz
Wed Aug 05 09:14:00 2009: TotalIRLen = 9, IRPrint = 0x0011
Wed Aug 05 09:14:01 2009: Found Cortex-M3 r1p1, Little endian.
Wed Aug 05 09:14:01 2009: TPIU fitted.
Wed Aug 05 09:14:01 2009:   FPUnit: 6 code (BP) slots and 2 literal slots
Wed Aug 05 09:14:01 2009: SYSRESETREQ has confused core. Trying to reconnect and use VECTRESET.
Wed Aug 05 09:14:04 2009: CPU did not halt, trying to disable WDT.
Wed Aug 05 09:14:04 2009: Core did not halt after reset, trying to disable WDT.
Wed Aug 05 09:14:07 2009: CPU did not halt, trying to disable WDT.
Wed Aug 05 09:16:55 2009: Fatal error: Bad JTAG communication: Write to IR: Expected 0x1, got 0xd (TAP Command : 14) @ Off 0x5.
Wrong AHB ID (15:3). Expected 0x04770001 (Mask 0x0FFFFF0F), Found 0x00000000
Session aborted!
Wed Aug 05 09:21:40 2009: Failed to load flash loader: C:\Program Files\IAR Systems\Embedded Workbench 5.0 Evaluation\ARM\config\flashloader\ST\FlashSTM32F10**RAM16K.out
 楼主| tomzxq 发表于 2009-8-5 09:33 | 显示全部楼层
因为图片不能上传,只能截取debug log,下载是会出现两个错误窗口,也是关于
