[Actel FPGA] A3P250 下载
2348|2
 楼主| li0411 发表于 2008-3-21 11:00 | 显示全部楼层 |阅读模式
我自制的板子,准备用A3P060芯片做专用控制器。<br />FlashPro软件提示下面错误:<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Signal&nbsp;Integrity&nbsp;Failure<br />Integrity&nbsp;Check&nbsp;Pattern&nbsp;Not&nbsp;Found.<br />Integrity&nbsp;Check&nbsp;Pattern&nbsp;:<br />550FAAF000FF0000FFFF<br />IrScan&nbsp;Error.<br />Possible&nbsp;chain&nbsp;exceeds&nbsp;expected&nbsp;maximum&nbsp;device&nbsp;count:&nbsp;256.<br />Chain&nbsp;Analysis&nbsp;Failed.<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Data&nbsp;Bit&nbsp;length&nbsp;:&nbsp;8272<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Compare&nbsp;Data&nbsp;:&nbsp;81D6035A78007F0000FFFF000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Scan&nbsp;Chain&nbsp;FAILED.<br />Error:&nbsp;Failed&nbsp;to&nbsp;run&nbsp;Action.<br /><br />
 楼主| li0411 发表于 2008-3-21 11:08 | 显示全部楼层
cuowu
我自制的板子,芯片是用A3P250芯片做专用控制器。
 楼主| li0411 发表于 2008-3-24 16:02 | 显示全部楼层
解决拉
V-JATG上拉电阻不用
