dsp进不了Enulator 请问以下是什么原因造成的,请高人指点<br /><br />(测到:sysClk正常,tck tdi正常,无tdo,而且clkout不稳定)<br /><br />Error connecting to the target:<br />Error 0x80000240/-291<br />Fatal Error during: Initialization, OCS, <br />This error was generated by TI's USCIF driver.<br /><br />SC_ERR_TST_MEASURE <-291><br />The built-in scan-path length measurement has failed. This indicates<br />that the JTAG controller cannot reliably communicate with<br />the target DSP's and micro-controllers at that frequency.<br />Try specifying the scan-path lengths in the board configuration<br />file because the built-in scan-path reliability tests cannot be<br />performed without knowledge of the scan-path length.<br /><br /><br />Sequence ID: 0<br />Error Code: -291<br />Error Class: 0x80000240<br /><br />Board Name: C6455 XDS560 Emulator<br />Cpu Name: C6400PLUS_0<br /><br />Abort: Close Code Composer Studio.<br />Retry: Try to connect to the target again.<br />Cancel: Remain disconnected from the target<br />Diagnostic: Run diagnostic utility.<br /> |
