请教
3792|18
 楼主| dankin 发表于 2007-5-5 16:43 | 显示全部楼层 |阅读模式
KEY.C(1): error C129: missing ';' before 'digbit'
上面是我在编译程序时的一个错误提示,但我不明白它是什么意思.程序是一个电子密码锁的一个程序,但无法进行编译,望各位前辈指点一二,谢谢.
ayb_ice 发表于 2007-5-5 16:45 | 显示全部楼层
可能是程序哪个地方缺少标点符号...
 楼主| dankin 发表于 2007-5-5 17:27 | 显示全部楼层
请教
谢谢ayb_ice
但是我都找了没有发现全程序如下
uchar digbit;
uchar wordbuf[6];
uchar tlcount;
uchar count;
uchar pw[6];
uchar pwbuf[6];
bit enterflag;
bit showflag;
sbit green=p3^0;
sbit red=p3^1;
void delay(void)
   uchar i;
   for (i=300;i>0;i--);
uchar keyscan (void)
  uchar scancode,tmpcode;
  p1=0xf0;
  if((p1&0xf0)!=0xf0)
     delay();
     if((p1&0xf0)!=0xfe;
      scancode=0xfe;
      while((scancode&0x10)!=0)
         p1=scancode;
         if((p1&0xf0)!=0xf0)
             tmpcode=(p1&0xf0)|0x0f;
              return((~scancode)+(~tmpcode));
             else scaccode=(scancode<<1)|0x01;
   return (0);
void time0_int(void) interrupt 1
   TH0 = -2000/256;
   TLO = -200%256;
   if (showflag==1)
       display();
 void time1_int(void) interrupt 3
 uchar k;
 TH1 = -50000/256;
 TL1 = -50000%256;
if (tlcount<20)
   tlcont++;
else
  TR1=0;
  tlcount = 0;
  green = 1;
  red =1;
showflag=1;
digbit = 0x01;
for (k=0;k<6;k++)
    wordbuf[k] =8;
uchar getcode(uchar i)
   uchar p;
 switch (i)
     case 0: p=0x3F;  break;
     case 1: p=0x06;  break;
     case 2: p=0x5B;  break;
     case 3: p=0x4F;  break;
     case 4: p=0x66;  break;
     case 5: p=0x6D;  break;
     case 6: p=0x7D;  break;
     case 7: p=0x07;  break;
     case 8: p=0x7F;  break;
     case 9: p=0x67;  break;
     case 10:p=0x77;  break;
     case 11:p=0x7c;  break;
     case 12:p=0x39;  break;
     case 13:p=0x5e;  break;
     case 14:p=0x79;  break;
     case 15:p=0x71;  break;
     default:         break;
 return (p);
void display (void)
 uchar i;
 switch (digbit)
   case 1:    i=0;   break;
   case 2:    i=1;   break;
   case 4:    i=2;   break;
   case 8:    i=3;   break;
   case 16:   i=4;   break;
   case 32:   i=5;   break;
   default:          break;
   p2=0x0;
   p0= getcode(wordbuf)
   p2=digbit ;
   if (digbit<0x20)
       digbit =digbit*2;
    else
      digbit=0x01;
bit pwcmp (void)
 bit flag;
 uchar i;
 for (i=0;i<6;i++)
   if (pw=pwbuf)
        flag=1
    else
    flag=0;
    i=6;
 return(flag);
void main( )
  uchar j ,key;
 p2=0x0;
 TMOD=0x11;
 THO=-2000/256;
 TLO=2000%256;
 TH1=-50000/256;
 TL1=-50000%256;
 TR0=1;
 ET0=1;
 TR1=0;
 ET1=1;
 EA=1;
  count=0;
  enterflag=0;
  pwflag=0;
  green=1;
  red=1;
  pw[0]=1;
  pw[1]=1;
  pw[2]=2;
  pw[3]=4;
  pw[4]=5;
  pw[5]=3;
 showflag=1;
 for (j=0;j<6;j++)
    wordbuf[j]=8;
 digbit = 0x01;
 while(1)
   key = keyscan();
   switch(key)
     case 0x11:
          if (count<6)
            wordbuf[count]=0x0f;
            pwbuf[count]=0;
            count++;
          break;
     case 0x21:
          if (count<6)
             pwbuf[count]=1;
             count++;
            break;
     case 0x41:
           if (count<6)
           pwbuf[count]=2;
           count++;
            break;
      case 0x81:
           if (count<6)
             pwbuf[count]=3;
             count++;
             break;
       case 0x12:
            if (count<6)
             pwbuf[count]=4;
             count++;
             break;
        case 0x22:
             if (count<6)
              pwbuf[count]=5;
              count++;
              break;
         case 0x42:
              if (count<6)
               pwbuf[count]=6;
               count++;
               break;
         case 0x82:
              if (count<6)
                pwbuf[count]=7;
                count++
                break;
         case 0x14:
              if (count<6)
                pwbuf[count]=8;
                count++;
                break;
         case 0x24:
              if (count<6)
               pwbuf[count]=9;
               count++;
               break;
         case 0x44:
              enterflag=1;
              if (count=6)
                 pwflag=pwcmp();
               else
                 pwflag=0;
               break;
         case 0x84:
              count=0;
             for (j=0;j<6;j++)
                wordbuf[j]=8;
                pwbuf[j]=0x0f;
               break;
          default : break;
 if (enterflag==1)
   enterflag=0;
   count=0;
   for(j=0;j<6;j++)
      pwbuf[j]=0x0f;
   showflag=0;
   TR1=1;
   tlcount=0;
   if (pwflag==1)
      green=0;
    else
      red=0;
烦请各位前辈指点
turmary 发表于 2007-5-5 17:51 | 显示全部楼层
uchar是自定义类型
要在最前面加这个
#define uchar unsigned char
 楼主| dankin 发表于 2007-5-5 18:43 | 显示全部楼层
请教
turmary你好,我加上去以后,问题更多了,提示如下
KEY.C(16): error C202: 'p3': undefined identifier
KEY.C(17): error C202: 'p3': undefined identifier
KEY.C(26): error C202: 'p1': undefined identifier
KEY.C(27): error C202: 'p1': undefined identifier
KEY.C(30): error C202: 'p1': undefined identifier
KEY.C(34): error C202: 'p1': undefined identifier
KEY.C(35): error C202: 'p1': undefined identifier
KEY.C(37): error C202: 'p1': undefined identifier
KEY.C(40): error C202: 'scaccode': undefined identifier
Target not created
麻烦指点一下
happystar 发表于 2007-5-5 19:20 | 显示全部楼层
re
你缺少定义P1,P2的头文件了.比如如果是89C51要加#include <reg51.h>
还有你明显没定义scaccode这个变量
hdm616 发表于 2007-5-5 19:20 | 显示全部楼层
没有头文件
zhaoyu2005 发表于 2007-5-5 19:54 | 显示全部楼层
p0= getcode(wordbuf[i])
你看不是少了“;”?还是不细心,都告诉你了C129: missing ';' before 'digbit'(129行,digbit前面丢失“;”),安一个金山词霸吧
 楼主| dankin 发表于 2007-5-6 17:17 | 显示全部楼层
请教
首先谢谢各位前辈的指点,但是我加上头文件也不能编译,还是一样的提示,我在P0后面加上一个;号后,提示一样,不知道是那里的问题望各位前辈再指点一下,各位前辈那里有没有能编译调试过的程序,发给我看一下好吗,看看在我这能调吗谢谢
天隼之翼 发表于 2007-5-6 17:24 | 显示全部楼层
你去我那个I2C求助的贴子里
那里有一长段I2C从机的程序,肯定能编译的,只不过在效果上不太好
 楼主| dankin 发表于 2007-5-6 17:27 | 显示全部楼层
你好
天隼之翼你那贴子从那里进入呢
 楼主| dankin 发表于 2007-5-6 17:53 | 显示全部楼层
请教
这个问题跟软件有关吗,我换了好多程序都不能运行,请前辈多多指点,谢谢
有梦就去追 发表于 2007-5-7 00:59 | 显示全部楼层
P要大写
 看你的P好像是小写的
c语言区分大小写吧
renrongwen 发表于 2007-5-7 01:22 | 显示全部楼层
调试好的代码,建议好好看看C51编程规范
#include <reg51.h>
#include <intrins.h>
#define uint  unsigned int
uchar digbit;
uchar wordbuf[6];
uchar tlcont;
uchar count;
uchar pw[6];
uchar pwbuf[6];
bit enterflag;
bit showflag;
bit pwflag;
sbit green=P3^0;
sbit red=P3^1;
void delay(void)
   uchar i;
  P1=0xf0;
  if((P1&0xf0)!=0xf0)
     delay();
     if((P1&0xf0)!=0xfe);
      scancode=0xfe;
         P1=scancode;
         if((P1&0xf0)!=0xf0)
             tmpcode=(P1&0xf0)|0x0f;
             else scancode=(scancode<<1)|0x01;
   return (0);
   uchar p;
switch (i)
     default:         break;
return (p);
void display(void)
    uchar i;
    switch (digbit)
       case 1:    i=0;   break;
       case 2:    i=1;   break;
       case 4:    i=2;   break;
       case 8:    i=3;   break;
       default:          break;
   P2=0x0;
   P0= getcode(wordbuf);
   P2=digbit;
   if (digbit<0x20)
       digbit =digbit*2;
    else
      digbit=0x01;
   TH0 = -2000/256;
   TL0 = -200%256;
   if (showflag==1)
       display();
uchar k;
TH1 = -50000/256;
TL1 = -50000%256;
if (tlcont<20)
   tlcont++;
else
  TR1=0;
  tlcont=0;
  green=1;
  red =1;
showflag=1;
digbit = 0x01;
for (k=0;k<6;k++)
    wordbuf[k] =8;
bit pwcmp(void)
bit flag;
uchar i;
for (i=0;i<6;i++)
   if (pw=pwbuf)
        flag=1;
    else
    flag=0;
    i=6;
return(flag);
void main( )
  uchar j ,key;
P2=0x0;
TMOD=0x11;
TH0=-2000/256;
TL0=2000%256;
TH1=-50000/256;
TL1=-50000%256;
TR0=1;
ET0=1;
TR1=0;
ET1=1;
EA=1;
  count=0;
  enterflag=0;
  pwflag=0;
  green=1;
  red=1;
  pw[0]=1;
  pw[1]=1;
  pw[2]=2;
  pw[3]=4;
  pw[4]=5;
  pw[5]=3;
showflag=1;
for (j=0;j<6;j++)
    wordbuf[j]=8;
digbit = 0x01;
while(1)
   key = keyscan();
   switch(key)
     case 0x11:
          if (count<6)
            pwbuf[count]=0;
            count++;
          break;
     case 0x21:
          if (count<6)
             pwbuf[count]=1;
             count++;
            break;
     case 0x41:
           if (count<6)
           pwbuf[count]=2;
           count++;
            break;
      case 0x81:
           if (count<6)
             pwbuf[count]=3;
             count++;
             break;
       case 0x12:
            if (count<6)
             pwbuf[count]=4;
             count++;
             break;
        case 0x22:
             if (count<6)
              pwbuf[count]=5;
              count++;
              break;
         case 0x42:
              if (count<6)
               pwbuf[count]=6;
               count++;
               break;
         case 0x82:
              if (count<6)
                pwbuf[count]=7;
                count++;
                break;
         case 0x14:
              if (count<6)
                pwbuf[count]=8;
                count++;
                break;
         case 0x24:
              if (count<6)
               pwbuf[count]=9;
               count++;
               break;
         case 0x44:
              enterflag=1;
              if (count=6)
                 pwflag=pwcmp();
               else
                 pwflag=0;
               break;
         case 0x84:
              count=0;
             for (j=0;j<6;j++)
                wordbuf[j]=8;
                pwbuf[j]=0x0f;
               break;
          default : break;
if (enterflag==1)
   enterflag=0;
   count=0;
   for(j=0;j<6;j++)
      pwbuf[j]=0x0f;
   showflag=0;
   TR1=1;
   tlcont=0;
   if (pwflag==1)
      green=0;
    else
      red=0;
renrongwen 发表于 2007-5-7 01:25 | 显示全部楼层
C51规范
http://www.baidu.com/s?wd=C51++%B9%E6%B7%B6&cl=3
DEF 发表于 2007-5-7 02:06 | 显示全部楼层
是少了;号
你贴上来的程序上就有这样的错误!!
你自己细心找找吧 在display函数里
ayb_ice 发表于 2007-5-7 07:33 | 显示全部楼层
这些都是简单的错误...
这些都是简单的错误,看来你还要学习基本的C知识...
zxq1234508 发表于 2007-5-7 08:35 | 显示全部楼层
错误有三
1、没有头文件。2、 p0、p1。。。的p应大写。3、 p0= getcode(wordbuf)
这句没有加“;”。
 楼主| dankin 发表于 2007-5-9 15:19 | 显示全部楼层
谢谢
renrongwen
首先非常感谢你,也感谢各位前辈的指点,使我又学了许多,谢谢你们,我一定好好学习,同时也希望各位前辈以后多多指点哦,再次谢谢你们
