头疼 buffer 端口
2363|0
 楼主| gggman 发表于 2007-5-11 12:36 | 显示全部楼层 |阅读模式
小弟进来做个小程序&nbsp;仿真过不了!<br />index&nbsp;是个buffer端口&nbsp;通过查表所得数值与其做加法运算&nbsp;然后传给下一级使用,同时返回给输入端,由下一个输入再次更新~~<br />程序如下<br />--------------------------------------------------------------------<br /><br />------------<br />--&nbsp;Company:&nbsp;<br />--&nbsp;Engineer:<br />--<br />--&nbsp;Create&nbsp;Date:&nbsp;&nbsp;&nbsp;&nbsp;22:48:39&nbsp;05/04/07<br />--&nbsp;Design&nbsp;Name:&nbsp;&nbsp;&nbsp;&nbsp;<br />--&nbsp;Module&nbsp;Name:&nbsp;&nbsp;&nbsp;&nbsp;kuis_1&nbsp;-&nbsp;Behavioral<br />--&nbsp;Project&nbsp;Name:&nbsp;&nbsp;&nbsp;<br />--&nbsp;Target&nbsp;Device:&nbsp;&nbsp;<br />--&nbsp;Tool&nbsp;versions:&nbsp;&nbsp;<br />--&nbsp;Description:<br />--<br />--&nbsp;Dependencies:<br />--&nbsp;<br />--&nbsp;Revision:<br />--&nbsp;Revision&nbsp;0.01&nbsp;-&nbsp;File&nbsp;Created<br />--&nbsp;Additional&nbsp;Comments:<br />--&nbsp;<br />--------------------------------------------------------------------<br /><br />------------<br />library&nbsp;IEEE;<br />use&nbsp;IEEE.STD_LOGIC_1164.ALL;<br />use&nbsp;IEEE.STD_LOGIC_ARITH.ALL;<br />use&nbsp;IEEE.STD_LOGIC_UNSIGNED.ALL;<br /><br />----&nbsp;Uncomment&nbsp;the&nbsp;following&nbsp;library&nbsp;declaration&nbsp;if&nbsp;instantiating<br />----&nbsp;any&nbsp;Xilinx&nbsp;primitives&nbsp;in&nbsp;this&nbsp;code.<br />--library&nbsp;UNISIM;<br />--use&nbsp;UNISIM.VComponents.all;<br /><br />entity&nbsp;kuis_1&nbsp;is<br />&nbsp;&nbsp;&nbsp;&nbsp;Port&nbsp;(&nbsp;code&nbsp;:&nbsp;in&nbsp;std_logic_vector(3&nbsp;downto&nbsp;0);<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;index&nbsp;:&nbsp;buffer&nbsp;std_logic_vector(8&nbsp;downto&nbsp;0));<br />end&nbsp;kuis_1;<br /><br />architecture&nbsp;Behavioral&nbsp;of&nbsp;kuis_1&nbsp;is<br />function&nbsp;adder9<br />&nbsp;&nbsp;&nbsp;&nbsp;(&nbsp;a:std_logic_vector;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;b:std_logic_vector<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;std_logic_vector&nbsp;is<br />variable&nbsp;vsum&nbsp;:&nbsp;std_logic_vector(8&nbsp;downto&nbsp;0);<br />variable&nbsp;carry&nbsp;:&nbsp;std_logic;<br />variable&nbsp;i:integer;<br />begin&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;carry&nbsp;:='0';<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;for&nbsp;i&nbsp;in&nbsp;0&nbsp;to&nbsp;8&nbsp;loop<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;vsum(i):=&nbsp;(a(i)&nbsp;xor&nbsp;b(i))&nbsp;xor&nbsp;carry;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;carry&nbsp;:=&nbsp;(a(i)&nbsp;and&nbsp;b(i))&nbsp;or&nbsp;(carry&nbsp;and&nbsp;(a(i)&nbsp;or&nbsp;b(i)));<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;loop;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;vsum;<br />end&nbsp;adder9;<br />signal&nbsp;tmp:std_logic_vector(8&nbsp;downto&nbsp;0);<br />signal&nbsp;tmp1:std_logic_vector(8&nbsp;downto&nbsp;0);<br />begin<br />p1:process(code)<br />begin<br />&nbsp;&nbsp;&nbsp;&nbsp;case&nbsp;code&nbsp;is<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;0000&quot;=&gt&nbsp;tmp&lt=&quot;111111111&quot;;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;0001&quot;=&gt&nbsp;tmp&lt=&quot;111111111&quot;;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;0010&quot;=&gt&nbsp;tmp&lt=&quot;111111111&quot;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;0011&quot;=&gt&nbsp;tmp&lt=&quot;111111111&quot;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;0100&quot;=&gt&nbsp;tmp&lt=&quot;000000010&quot;;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;0101&quot;=&gt&nbsp;tmp&lt=&quot;000000100&quot;;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;0110&quot;=&gt&nbsp;tmp&lt=&quot;000000110&quot;;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;0111&quot;=&gt&nbsp;tmp&lt=&quot;000001000&quot;;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;1000&quot;=&gt&nbsp;tmp&lt=&quot;111111111&quot;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;1001&quot;=&gt&nbsp;tmp&lt=&quot;111111111&quot;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;1010&quot;=&gt&nbsp;tmp&lt=&quot;111111111&quot;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;1011&quot;=&gt&nbsp;tmp&lt=&quot;111111111&quot;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;1100&quot;=&gt&nbsp;tmp&lt=&quot;000000010&quot;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;1101&quot;=&gt&nbsp;tmp&lt=&quot;000000100&quot;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;1110&quot;=&gt&nbsp;tmp&lt=&quot;000000110&quot;;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&quot;1111&quot;=&gt&nbsp;tmp&lt=&quot;000001000&quot;;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;when&nbsp;others=&gt&nbsp;tmp&lt=&quot;ZZZZZZZZZ&quot;;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;case;<br />end&nbsp;process&nbsp;p1;<br />p2:process(tmp,index)<br />begin<br />tmp1&lt=adder9(index,tmp);<br />index&lt=tmp1;<br />end&nbsp;process&nbsp;p2;<br />end&nbsp;Behavioral;<br />
