STVD7 编译问题找不到st7.tab
3169|1
 楼主| peter9177 发表于 2007-9-12 10:54 | 显示全部楼层 |阅读模式
----------- Project 72f324 - ST7 Assembler Linker - Configuration Debug -------------
Assembling power_on.asm...
asm power_on.asm -I=C:\My_work\include  -obj=Debug\power_on.obj
Couldn't open table file 'C:\STMicroelectronics\st7toolset\asm\;st7.tab': No such file or directory
STMicroelectronics - Assembler - rel. 4.48
 The command: "asm power_on.asm -I=C:\My_work\include  -obj=Debug\power_on.obj" has failed, the returned value is: 2
exit code=2.
72f324.s19 - 1 error(s), 0 warning(s)
zl_777 发表于 2007-9-14 17:33 | 显示全部楼层
你用汇编写的吗?
你的程序是用汇编写的,请在程序的第一行加一个“st7/”,注意要顶格写。
