高手帮忙!为什么连接不上DSP了..
7594|3
 楼主| ian11122840 发表于 2009-4-1 19:01 | 显示全部楼层 |阅读模式
DSP, TI, rc, TE, se
今天试着烧一个别人给的FLASH程序,烧的时候提示“会烧到RAM区,可能无法上电自运行”,我点了“忽视”,只是想试一下。结果烧完测试无法自运行..那也就算了..问题是为什么现在连仿真器都连不上去了呢?<br /><br />点“connect”,出现致命错误:<br /><br />Error&nbsp;connecting&nbsp;to&nbsp;the&nbsp;target:<br />Error&nbsp;0x80000240/-121<br />Fatal&nbsp;Error&nbsp;during:&nbsp;Initialization,&nbsp;OCS,&nbsp;<br />This&nbsp;error&nbsp;was&nbsp;generated&nbsp;by&nbsp;TI's&nbsp;USCIF&nbsp;driver.<br /><br />SC_ERR_CMD_HANDLE&nbsp;&lt-121&gt<br />A&nbsp;bad&nbsp;controller&nbsp;handle&nbsp;has&nbsp;been&nbsp;given&nbsp;to&nbsp;a&nbsp;function,<br />either&nbsp;before&nbsp;attempting&nbsp;to&nbsp;open&nbsp;the&nbsp;controller,&nbsp;or&nbsp;after<br />having&nbsp;opened&nbsp;the&nbsp;controller&nbsp;and&nbsp;ignored&nbsp;its&nbsp;error&nbsp;status.<br />Valid&nbsp;controller&nbsp;handles&nbsp;are&nbsp;generated&nbsp;when&nbsp;attempts<br />to&nbsp;open&nbsp;the&nbsp;controller&nbsp;return&nbsp;a&nbsp;clean&nbsp;error&nbsp;status.<br /><br /><br />Sequence&nbsp;ID:&nbsp;0<br />Error&nbsp;Code:&nbsp;-121<br />Error&nbsp;Class:&nbsp;0x80000240<br />I/O&nbsp;Port&nbsp;=&nbsp;240<br /><br />Board&nbsp;Name:&nbsp;F2812&nbsp;XDS510&nbsp;Emulator<br />Cpu&nbsp;Name:&nbsp;CPU_1<br /><br />之后点“Retry”的话,出的是另外一个错误代码:<br /><br />Error&nbsp;connecting&nbsp;to&nbsp;the&nbsp;target:<br />Error&nbsp;0x80000200/-1037<br />Fatal&nbsp;Error&nbsp;during:&nbsp;OCS,&nbsp;<br />PTI_ERR_EMU_CLOSE&nbsp;Error&nbsp;Occured&nbsp;at&nbsp;0x00000000<br /><br /><br />Sequence&nbsp;ID:&nbsp;0<br />Error&nbsp;Code:&nbsp;-1037<br />Error&nbsp;Class:&nbsp;0x80000200<br />I/O&nbsp;Port&nbsp;=&nbsp;240<br /><br />Board&nbsp;Name:&nbsp;F2812&nbsp;XDS510&nbsp;Emulator<br />Cpu&nbsp;Name:&nbsp;CPU_1<br /><br /><br />晕啊...难道是哪里烧了?不至于吧?这是怎么回事呢?知道的大侠一定要帮帮忙!
lplplplp 发表于 2009-4-1 22:45 | 显示全部楼层
过路过路过
hotpower 发表于 2009-4-1 23:49 | 显示全部楼层
俺一直没敢烧写过,所以菜鸟总毕业不了~~~
kubuco 发表于 2009-4-3 09:59 | 显示全部楼层
我也没烧过。。。呵呵。。一直用仿真器跑。。呵呵。
