帮忙看看,link出错误,请教怎么解决啊!
2677|5
 楼主| kunasen 发表于 2009-5-12 22:13 | 显示全部楼层 |阅读模式
Linking..
LMM info: area 'InterruptRAM' uses 73 bytes in SRAM page 0
LMM info: area 'UART_RAM' item of 32 bytes allocated in SRAM page 0
LMM info: area 'data' item of 4 bytes allocated in SRAM page 0
LMM info: area 'virtual_registers' uses 2 bytes in SRAM page 0
LMM info: area 'data' item of 2 bytes allocated in SRAM page 0
LMM info: area 'data' item of 1 bytes allocated in SRAM page 0
!W warning: the value 0 is written to location 0x163 more than once.
!W warning: the value 0 is written to location 0x172 more than once.
!E C:\PROGRA~1\Cypress\Common\CY3E64~1\tools\Overlap.txt(0) Address from 0x150 to 0x17a already contains a value
C:\PROGRA~1\Cypress\Common\CY3E64~1\tools\make: *** [output/HID_Example.rom] Error 1
ni_labview 发表于 2009-5-12 22:50 | 显示全部楼层
兄弟您这是哪种芯片,是在5.0还是4.4环境下编译
C语言,还是汇编写的,请说明,大家帮忙看看
 楼主| kunasen 发表于 2009-5-12 22:53 | 显示全部楼层
C语言的,谢谢大家了
C语言的,谢谢大家了
 楼主| kunasen 发表于 2009-5-12 22:54 | 显示全部楼层
CY7C64215,5.0SP4
jxin 发表于 2009-5-13 11:02 | 显示全部楼层
试试
Project >> Settings >> Linker - 'Relocatable code start address' 改大一些试试,例如400
 楼主| kunasen 发表于 2009-5-14 13:49 | 显示全部楼层
谢谢各位
谢谢ni_labview、jxin,是这个问题,改大一些的地址就可以了
