LOAD: Configuration 'BOOT_FLASH' in the project 'Project' contains broken options for tool 'XLINK': The format of this file is not supported by this version of the workbench. It appears to have been written by a newer version of the workbench. Diagnostics: 'Unsupported version 8 of list option descriptor 'FormatVariant''. Options for 'XLINK' will be set to default. Creating backup of original project file. LOAD: Configuration 'BOOT_RAM' in the project 'Project' contains broken options for tool 'XLINK': The format of this file is not supported by this version of the workbench. It appears to have been written by a newer version of the workbench. Diagnostics: 'Unsupported version 8 of list option descriptor 'FormatVariant''. Options for 'XLINK' will be set to default. 我用IAR打开官方网站下的例程打开报上面这个错误,下载也不能正常下载。用串口1下载,上位机软件也连不上。波特率设置11500,8个数据位、1个停止位,偶校验。设置有问题吗?我用的开发板是EK-STM32F.JTAG和usb都连不上。
