K08,16,24 and 32(the shift key) keys can be pushed simultaneously with other keys (the normal keys).
However, the simultaneous keying of the shift keys and that of the normal keys are prohibited.
既然shift keys可以与其他键同时按, 为什么后面有说被禁止?
the system code setting is made by the diode jumper between "CODE" line and "K0~K6" lines . with diode jumper, data code will become "1".
however, if the setting of "CODE" AND "K0~K6" keys is only at one point, (不明白)the keys are connectable directly without using the diode jumper. |
