强悍!——俄罗斯老毛子的 OSA-RTOS for PIC
5950|4
 楼主| hsw_21 发表于 2009-9-23 20:20 | 显示全部楼层 |阅读模式
http://picosa.narod.ru/
[td] [td]
[size=+2]OSA - RTOS (real-time operating system) for Microchip PIC-controllers.
[size=+0]Support controllers: PIC10, PIC12, PIC16, PIC18, PIC24 and dsPIC.
OSA works with compilers:
  • HT-PICC std [size=-1](PIC10, PIC12, PIC16)
  • HT-PICC18 std [size=-1](PIC18)
  • Microchip C18 [size=-1](PIC18)
  • Microchip C30 [size=-1](PIC24, dsPIC)
  • mikroC PRO [size=-1](PIC18)
  • CCS [size=-1](PIC12, PIC16, PIC18)
[size=+5]___________________
[td][size=-1](OSA version is periodically updated).
(If you have any questions you can mail me.)
[td]_________________________
16.07.2009 [td]1. Bug fixed for CCS18: OS_InitDelay worked incorrectly
2. Added example for MCC18
07.07.2009 [td][size=-1]1. Bug fixed: OS_EI was defined incorrectly for MCC18
2. Macros for work with tasks did not work with CCS (now braces around parameter pTask are removed)
01.07.2009 [td][size=-1]1. OSA ported for microC PRO 2.15 (only PIC18)
2. OSA ported for CCS (PIC16 and PIC18)
ddb_21ic 发表于 2009-9-25 10:38 | 显示全部楼层
size=-1,这还真是高科技
bcaiyo 发表于 2009-12-22 15:57 | 显示全部楼层
有人在用吗?
我是土匪 发表于 2011-11-29 13:20 | 显示全部楼层
正在研究
ayb_ice 发表于 2011-12-1 11:26 | 显示全部楼层
先保存再说
