[国产单片机] 15W4K56S4SPI模块与端口扩展芯片MCP23S17通信不成功
1139|1
 楼主| yxys_1988 发表于 2016-2-16 14:17 | 显示全部楼层 |阅读模式
附源程序希望大神帮忙看看,示波器测试波形都是有的。
#include   "my_include.h"
#define   MCP_ADDR  0x40
#define   IODIRA    0x00
#define   IODIRB    0x01
#define   IOCONA    0x0A
#define   IOCONB    0x0B
#define   GPIOA     0x12
#define   GPIOB     0x13
#define   OLATA     0x14
#define   OLATB     0x15
#define   SPIF      0x80
#define   WCOL      0x40
sbit CS2 = P1^0;                                //U2片选
sbit CS3 = P1^1;                                //U3片选
sbit CS4 = P1^2;                                //U4片选
sbit CS5 = P1^6;                                //U5片选
sbit CS6 = P1^7;                                //U6片选(低有效)
sbit LED19 = P2^4;
sbit LED18 = P2^5;
sbit LED17 = P2^6;
sbit LED21 = P3^7;
void GPIO_config (void)
        GPIO_InitTypeDef        GPIO_InitStructure;                                //结构定义
        GPIO_InitStructure.Pin  = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_6 | GPIO_Pin_7;        //指定要初始化的IO, GPIO_Pin_0 ~ GPIO_Pin_7, 或操作
        GPIO_InitStructure.Mode = GPIO_PullUp;                                //指定IO的输入或输出方式,GPIO_PullUp,GPIO_HighZ,GPIO_OUT_OD,GPIO_OUT_PP
        GPIO_Inilize(GPIO_P1,&GPIO_InitStructure);                        //初始化
           GPIO_InitStructure.Pin  = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;                    //指定要初始化的IO, GPIO_Pin_0 ~ GPIO_Pin_7, 或操作
        GPIO_Inilize(GPIO_P2,&GPIO_InitStructure);                        //初始化
        GPIO_InitStructure.Pin  = GPIO_Pin_7;                    //指定要初始化的IO, GPIO_Pin_0 ~ GPIO_Pin_7, 或操作
        GPIO_Inilize(GPIO_P3,&GPIO_InitStructure);
void SPI_init (void)
        SPCTL = 0xD0;
        SPDAT = 0;
        SPSTAT = SPIF | WCOL;
void SPI_Write_Byte (u8 dat)
    SPDAT = dat;
        while (!(SPSTAT & SPIF));
    SPSTAT=SPIF|WCOL;
u8 SPI_Read_Byte (void)
        u8 SPI_dat;
    SPDAT=0xFF;
    SPI_dat=SPDAT;
        SPSTAT=SPIF|WCOL;
        return SPI_dat;
void Wirte_MCP23S17 (u8 Device_Add, u8 Reg_Add, u8 dat)
        CS6 = 0;
        SPI_Write_Byte (Device_Add);
        SPI_Write_Byte (Reg_Add);
        SPI_Write_Byte (dat);
        CS6 = 1;
void Init_MCP23S17 ()
        Wirte_MCP23S17 (MCP_ADDR,IODIRA,0x00);
        Wirte_MCP23S17 (MCP_ADDR,IODIRB,0x00);
        Wirte_MCP23S17 (MCP_ADDR,GPIOA,0xFF);
        Wirte_MCP23S17 (MCP_ADDR,GPIOB,0xFF);
void main (void)
        LED19 = 0;
        GPIO_config ();
        GPIO_PWMInit(GPIO_PWM2,GPIO_PullUp);//设置为准双向口 凡是跟PWM相关的IO口上电都是高阻输入态
        GPIO_PWMInit(GPIO_PWM3,GPIO_PullUp);
        GPIO_PWMInit(GPIO_PWM4,GPIO_PullUp);
        GPIO_PWMInit(GPIO_PWM5,GPIO_PullUp);
        GPIO_PWMInit(GPIO_PWM6,GPIO_PullUp);
        GPIO_PWMInit(GPIO_PWM7,GPIO_PullUp);
        SPI_init ();
        Init_MCP23S17 ();
        while (1)
                Wirte_MCP23S17 (MCP_ADDR,GPIOA,0x00);
                Wirte_MCP23S17 (MCP_ADDR,GPIOB,0x00);
 楼主| yxys_1988 发表于 2016-2-16 16:47 | 显示全部楼层
希望大神解答(有偿)
