#include <reg52.h>
unsigned char code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
unsigned char temp;
unsigned char key;
unsigned char i,j;
void main(void)
while(1)
P3=0xff;
P3^4=0;
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
for(i=50;i>0;i--)
for(j=200;j>0;j--);
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
switch(temp)
case 0x0e:
key=7;
break;
case 0x0d:
key=8;
break;
case 0x0b:
key=9;
break;
case 0x07:
key=10;
break;
temp=P3;
P1^0=~P1^0;
P0=table[key];
temp=temp & 0x0f;
while(temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
P3=0xff;
P3_5=0;
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
for(i=50;i>0;i--)
for(j=200;j>0;j--);
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
switch(temp)
case 0x0e:
key=4;
break;
case 0x0d:
key=5;
break;
case 0x0b:
key=6;
break;
case 0x07:
key=11;
break;
temp=P3;
P1^0=~P1^0;
P0=table[key];
temp=temp & 0x0f;
while(temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
P3=0xff;
P3^6=0;
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
for(i=50;i>0;i--)
for(j=200;j>0;j--);
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
switch(temp)
case 0x0e:
key=1;
break;
case 0x0d:
key=2;
break;
case 0x0b:
key=3;
break;
case 0x07:
key=12;
break;
temp=P3;
P1^0=~P1^0;
P0=table[key];
temp=temp & 0x0f;
while(temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
P3=0xff;
P3^7=0;
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
for(i=50;i>0;i--)
for(j=200;j>0;j--);
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
switch(temp)
case 0x0e:
key=0;
break;
case 0x0d:
key=13;
break;
case 0x0b:
key=14;
break;
case 0x07:
key=15;
break;
temp=P3;
P1^0=~P1^0;
P0=table[key];
temp=temp & 0x0f;
while(temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
