static void systick_init(void) { RCC_ClocksTypeDef rcc_clocks; uint32_t cnts; SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK); RCC_GetClocksFreq(&rcc_clocks); cnts = (uint32_t)rcc_clocks.HCLK_Frequency / 25600; if ((cnts - 1UL) > SysTick_LOAD_RELOAD_Msk) { while(1); } /* Reload value impossible */ SysTick->LOAD = (uint32_t)(cnts - 1UL); /* set reload register */ NVIC_SetPriority (SysTick_IRQn, 0); /* set Priority highest */ SysTick->VAL = 0; /* Load the SysTick Counter Value */ SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk | SysTick_CTRL_TICKINT_Msk | SysTick_CTRL_ENABLE_Msk; /* Enable SysTick IRQ and SysTick Timer */ } static void EXTILine0_Config(void) { EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* Enable SYSCFG clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); /* Configure EXTI Line0 */ EXTI_InitStructure.EXTI_Line = EXTI_Line0; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_Init(&EXTI_InitStructure); /* Enable and set EXTI Line0 Interrupt to the lowest priority */ NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } /** * [url=home.php?mod=space&uid=247401]@brief[/url] Configures EXTI Line15 (connected to PG15 pin) in interrupt mode * @param None * @retval None */ static void EXTILine13_15_Config(void) { EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* Enable SYSCFG clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); /* Configure EXTI Line13 */ EXTI_InitStructure.EXTI_Line = EXTI_Line13; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_Init(&EXTI_InitStructure); /* Enable and set EXTI15_10 Interrupt to the lowest priority */ NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } static void exti_init(void) { EXTILine0_Config(); EXTILine13_15_Config(); } void period_init(void) { /* Configures the priority grouping: pre-emption priority and subpriority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); /* Sample periodic interrupt config */ systick_init(); /* Externel interrupt init */ exti_init(); } /** * [url=home.php?mod=space&uid=247401]@brief[/url] Main program * @param None * @retval None */ int main(void) { /* Timer, cycle sampling init */ period_init(); /* Infinite loop */ while (1) { } } int32_t short_interrupt_trig_cnt = 0; int32_t short_interrupt_cnt= 0; int32_t long_interrupt_trig_cnt = 0; int32_t long_interrupt_cnt= 0; /** * [url=home.php?mod=space&uid=247401]@brief[/url] Period sampling handler,512 pionts every cycle. * @param None * @retval None */ void SysTick_Handler(void) { static uint16_t counter = 0; counter++; /* 256 points,half cycle */ if ((counter&0x00FF) == 0x00FF) { /* Generate software interrupt */ EXTI_GenerateSWInterrupt(EXTI_Line0); short_interrupt_trig_cnt++; } /* 5120 points,ten cycles */ if (counter >= 5119) { counter = 0; /* Generate software interrupt */ EXTI_GenerateSWInterrupt(EXTI_Line13); long_interrupt_trig_cnt++; } } /** * [url=home.php?mod=space&uid=247401]@brief[/url] This function handles External line 0 interrupt request. * @param None * @retval None */ void EXTI0_IRQHandler(void) { if(EXTI_GetITStatus(EXTI_Line0) != RESET) { /* Clear the EXTI line 0 pending bit */ EXTI_ClearITPendingBit(EXTI_Line0); short_interrupt_cnt++; } } /** * [url=home.php?mod=space&uid=247401]@brief[/url] This function handles External lines 15 to 10 interrupt request. * @param None * @retval None */ void EXTI15_10_IRQHandler(void) { if(EXTI_GetITStatus(EXTI_Line13) != RESET) { /* Clear the EXTI line 13 pending bit */ EXTI_ClearITPendingBit(EXTI_Line13); //delay(0x1); long_interrupt_cnt++; } } 附上IAR工程,很方便移植到其它的STM32处理器上,感兴趣的可以测试一下!!
cpu.zip
2016-2-28 22:06 上传
点击文件名下载附件
943.08 KB, 下载次数: 9
收藏0 举报
airwill 发表于 2016-2-25 13:07 仿真, 不应该有这样的问题哪 我怀疑你的观察和检查方法是不是有问题?
Bermanrep 发表于 2016-2-26 09:11 楼主能否说一下你是如何仿真的,如何确定256点是正确的啊
lwsn 发表于 2016-2-27 20:40 楼主是怎么检查的,具体怎么操作的
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
发帖类勋章
时间类勋章
人才类勋章
等级类勋章
53
1821
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
