各位大侠:我按照触摸库三部去编译工程还是出现如下提示
Manual Linker Command fileIf you want to have more precisely the size taken by the Library for your configuration, you need to do the following: 1) Add the preprocessor definition USE_PRAGMA_SECTION (in the STVD settings for example).
2) Remove the Automatic LKF file and use instead the Linker command file present at the project root folder:
Project Settings -> Linker tab -> Script Lkf file name
3) Look the "Segments" chapter at the beginning of the generated map file.
上述详见触摸库CHM文件哈。有图我发不上来。
出现如下提示: unning Linker
clnk -lD:\STM8\CXSTM8\Lib -o Debug\touchlognmatch2.sm8 -mDebug\touchlognmatch2.map debug\touchlognmatch2.lkf
#error clnk debug\touchlognmatch2.lkf:1 no default placement for segment .TSL_RAM0
#error clnk debug\touchlognmatch2.lkf:1 no default placement for segment .TSL_CODE
#error clnk debug\touchlognmatch2.lkf:1 no default placement for segment .TSL_IO_CONST
#error clnk debug\touchlognmatch2.lkf:1 no default placement for segment .TSL_IO_ALCODE
#error clnk debug\touchlognmatch2.lkf:1 no default placement for segment .TSL_IO_RAM
#error clnk debug\touchlognmatch2.lkf:1 no default placement for segment .TSL_IO_CODE
#error clnk debug\touchlognmatch2.lkf:1 no default placement for segment .TSL_IO_RAM0
#error clnk debug\touchlognmatch2.lkf:1 no default placement for segment .CONFIG_CODE
The command: "clnk -lD:\STM8\CXSTM8\Lib -o Debug\touchlognmatch2.sm8 -mDebug\touchlognmatch2.map debug\touchlognmatch2.lkf " has failed, the returned value is: 1
exit code=1.
touchlognmatch2.elf - 11 error(s), 0 warning(s) |
