IAR5。4下载错误,求助
8863|8
 楼主| woshiwowo 发表于 2009-10-28 11:28 | 显示全部楼层 |阅读模式
在编译没有错误的情况下,在下载中出现了以下问题:
1、出现了一个提示框:
  显示:There were warnings while generating flash loader input.
See the Debug Log window for details.
2、点击了确定后,弹出:
Warning:There were warnings during download,see
3、再次点击确定后,在Log Window出现很多warning,类似:
Flash download warning: 64 out of 64 bytes from data record CODE:[0x00000000,0x0000003F] will not be flashed
Wed Oct 28 11:08:48 2009: Flash download warning: 35472 out of 35472 bytes from data record CODE:[0x00000100,0x00008B8F] will not be flashed
Wed Oct 28 11:08:48 2009: There were warnings while generating flash loader input.
Wed Oct 28 11:08:57 2009: Skipping flash loading pass because there is no data in the designated range: 0x100000-0x140000.
出现一大堆类似于以下的错误
Verify error at address 0x00000000, target byte: 0x0F, byte in file: 0x18
Verify error at address 0x00000001, target byte: 0x00, byte in file: 0xF0
Verify error at address 0x00000002, target byte: 0x00, byte in file: 0x9F
请高手们帮帮忙告诉我是怎么回事?!谢谢!!
yuhuihui 发表于 2009-10-28 17:02 | 显示全部楼层
我去帮你问问...
gainst 发表于 2009-10-28 22:03 | 显示全部楼层
关注..
我也在用IAR for ARM 5.4 片子是TI的..暂时还没有遇到这个问题 ..
daiminsdu 发表于 2013-3-15 08:59 | 显示全部楼层
楼主有没有解决这个问题,咋解决的啊?
zhou1994 发表于 2014-1-7 10:25 | 显示全部楼层
楼主,怎么解决的饿?
gufenglcc 发表于 2014-1-23 18:55 | 显示全部楼层
我也遇到了同样的问题file:///C:\Documents and Settings\Administrator\Application Data\Tencent\Users\563843773\QQ\WinTemp\RichOle\WLR6L61LB{X%MC`X$2RW_%9.jpgfile:///C:\Documents and Settings\Administrator\Application Data\Tencent\Users\563843773\QQ\WinTemp\RichOle\WLR6L61LB{X%MC`X$2RW_%9.jpgfile:///C:\Documents and Settings\Administrator\Application Data\Tencent\Users\563843773\QQ\WinTemp\RichOle\WLR6L61LB{X%MC`X$2RW_%9.jpg,首先是There were warnings while generating flash loader input.see the debug log window for details.
按了确定之后提示有There were 1 error and 4 warnings during  the intilalization of the debugging session,there is more information in the Debug Log window.
DO you want to continu with the "Run to"command?
天命风流 发表于 2018-4-10 11:01 | 显示全部楼层
没人解决么
能够微信求教一下吗,18656073826,谢谢  发表于 2019-2-20 11:59
MaNong123 发表于 2019-2-20 11:56 | 显示全部楼层
你好,你关于这个问题解决了吗,为什么iar编译代码的时候会在0x00000000编译一个字节,而下载的时候出现flash的警告 Flash download warning: 1 out of 1 bytes from data record CODE:[0x00000000,0x00000000] will not be flashed
