[汽车MCU – KEA] 有关KEIL5 枚举常量最大值的问题
2286|2
 楼主| jinyin986 发表于 2016-3-5 11:25 | 显示全部楼层 |阅读模式
我用在MDK518做KEA128编程时候,发现枚举常量赋值不能超过 1<<31,不然出现错误代码如下
typedef enum
    /* in GPIOA register */
    GPIO_PTA0_MASK = (1<<0),    /*!< GPIO Pin PTA0 bit mask */
    GPIO_PTA1_MASK = (1<<1),    /*!< GPIO Pin PTA1 bit mask */
    GPIO_PTA2_MASK = (1<<2),    /*!< GPIO Pin PTA2 bit mask */
    GPIO_PTA3_MASK = (1<<3),    /*!< GPIO Pin PTA3 bit mask */
    GPIO_PTA4_MASK = (1<<4),    /*!< GPIO Pin PTA4 bit mask */
    GPIO_PTA5_MASK = (1<<5),    /*!< GPIO Pin PTA5 bit mask */
    GPIO_PTA6_MASK = (1<<6),    /*!< GPIO Pin PTA6 bit mask */
    GPIO_PTA7_MASK = (1<<7),    /*!< GPIO Pin PTA7 bit mask */
    GPIO_PTB0_MASK = (1<<8),    /*!< GPIO Pin PTB0 bit mask */
    GPIO_PTB1_MASK = (1<<9),    /*!< GPIO Pin PTB1 bit mask */
    GPIO_PTB2_MASK = (1<<10),   /*!< GPIO Pin PTB2 bit mask */
    GPIO_PTB3_MASK = (1<<11),   /*!< GPIO Pin PTB3 bit mask */
    GPIO_PTB4_MASK = (1<<12),   /*!< GPIO Pin PTB4 bit mask */
    GPIO_PTB5_MASK = (1<<13),   /*!< GPIO Pin PTB5 bit mask */
    GPIO_PTB6_MASK = (1<<14),   /*!< GPIO Pin PTB6 bit mask */
    GPIO_PTB7_MASK = (1<<15),   /*!< GPIO Pin PTB7 bit mask */
    GPIO_PTC0_MASK = (1<<16),   /*!< GPIO Pin PTC0 bit mask */
    GPIO_PTC1_MASK = (1<<17),   /*!< GPIO Pin PTC1 bit mask */
    GPIO_PTC2_MASK = (1<<18),   /*!< GPIO Pin PTC2 bit mask */
    GPIO_PTC3_MASK = (1<<19),   /*!< GPIO Pin PTC3 bit mask */
    GPIO_PTC4_MASK = (1<<20),   /*!< GPIO Pin PTC4 bit mask */
    GPIO_PTC5_MASK = (1<<21),   /*!< GPIO Pin PTC5 bit mask */
    GPIO_PTC6_MASK = (1<<22),   /*!< GPIO Pin PTC6 bit mask */
    GPIO_PTC7_MASK = (1<<23),   /*!< GPIO Pin PTC7 bit mask */
    GPIO_PTD0_MASK = (1<<24),   /*!< GPIO Pin PTD0 bit mask */
    GPIO_PTD1_MASK = (1<<25),   /*!< GPIO Pin PTD1 bit mask */
    GPIO_PTD2_MASK = (1<<26),   /*!< GPIO Pin PTD2 bit mask */
    GPIO_PTD3_MASK = (1<<27),   /*!< GPIO Pin PTD3 bit mask */
    GPIO_PTD4_MASK = (1<<28),   /*!< GPIO Pin PTD4 bit mask */
    GPIO_PTD5_MASK = (1<<29),   /*!< GPIO Pin PTD5 bit mask */
    GPIO_PTD6_MASK = (1<<30),   /*!< GPIO Pin PTD6 bit mask */
    GPIO_PTD7_MASK = (1<<31),   /*!< GPIO Pin PTD7 bit mask */
    /* in GPIOB register */
    GPIO_PTE0_MASK = (1<<0),    /*!< GPIO Pin PTE0 bit mask */
    GPIO_PTE1_MASK = (1<<1),    /*!< GPIO Pin PTE1 bit mask */
    GPIO_PTE2_MASK = (1<<2),    /*!< GPIO Pin PTE2 bit mask */
    GPIO_PTE3_MASK = (1<<3),    /*!< GPIO Pin PTE3 bit mask */
    GPIO_PTE4_MASK = (1<<4),    /*!< GPIO Pin PTE4 bit mask */
    GPIO_PTE5_MASK = (1<<5),    /*!< GPIO Pin PTE5 bit mask */
    GPIO_PTE6_MASK = (1<<6),    /*!< GPIO Pin PTE6 bit mask */
    GPIO_PTE7_MASK = (1<<7),    /*!< GPIO Pin PTE7 bit mask */
    GPIO_PTF0_MASK = (1<<8),    /*!< GPIO Pin PTF0 bit mask */
    GPIO_PTF1_MASK = (1<<9),    /*!< GPIO Pin PTF1 bit mask */
    GPIO_PTF2_MASK = (1<<10),   /*!< GPIO Pin PTF2 bit mask */
    GPIO_PTF3_MASK = (1<<11),   /*!< GPIO Pin PTF3 bit mask */
    GPIO_PTF4_MASK = (1<<12),   /*!< GPIO Pin PTF4 bit mask */
    GPIO_PTF5_MASK = (1<<13),   /*!< GPIO Pin PTF5 bit mask */
    GPIO_PTF6_MASK = (1<<14),   /*!< GPIO Pin PTF6 bit mask */
    GPIO_PTF7_MASK = (1<<15),   /*!< GPIO Pin PTF7 bit mask */
    GPIO_PTG0_MASK = (1<<16),   /*!< GPIO Pin PTG0 bit mask */
    GPIO_PTG1_MASK = (1<<17),   /*!< GPIO Pin PTG1 bit mask */
    GPIO_PTG2_MASK = (1<<18),   /*!< GPIO Pin PTG2 bit mask */
    GPIO_PTG3_MASK = (1<<19),   /*!< GPIO Pin PTG3 bit mask */
    GPIO_PTG4_MASK = (1<<20),   /*!< GPIO Pin PTG4 bit mask */
    GPIO_PTG5_MASK = (1<<21),   /*!< GPIO Pin PTG5 bit mask */
    GPIO_PTG6_MASK = (1<<22),   /*!< GPIO Pin PTG6 bit mask */
    GPIO_PTG7_MASK = (1<<23),   /*!< GPIO Pin PTG7 bit mask */
    GPIO_PTH0_MASK = (1<<24),   /*!< GPIO Pin PTH0 bit mask */
    GPIO_PTH1_MASK = (1<<25),   /*!< GPIO Pin PTH1 bit mask */
    GPIO_PTH2_MASK = (1<<26),   /*!< GPIO Pin PTH2 bit mask */
    GPIO_PTH3_MASK = (1<<27),   /*!< GPIO Pin PTH3 bit mask */
    GPIO_PTH4_MASK = (1<<28),   /*!< GPIO Pin PTH4 bit mask */
    GPIO_PTH5_MASK = (1<<29),   /*!< GPIO Pin PTH5 bit mask */
    GPIO_PTH6_MASK = (1<<30),   /*!< GPIO Pin PTH6 bit mask */
    GPIO_PTH7_MASK = (1<<31),   /*!< GPIO Pin PTH7 bit mask */
    /* in GPIOC register */
    GPIO_PTI0_MASK = (1<<0),    /*!< GPIO Pin PTI0 bit mask */
    GPIO_PTI1_MASK = (1<<1),    /*!< GPIO Pin PTI1 bit mask */
    GPIO_PTI2_MASK = (1<<2),    /*!< GPIO Pin PTI2 bit mask */
    GPIO_PTI3_MASK = (1<<3),    /*!< GPIO Pin PTI3 bit mask */
    GPIO_PTI4_MASK = (1<<4),    /*!< GPIO Pin PTI4 bit mask */
    GPIO_PTI5_MASK = (1<<5),    /*!< GPIO Pin PTI5 bit mask */
    GPIO_PTI6_MASK = (1<<6),    /*!< GPIO Pin PTI6 bit mask */
    GPIO_PTI7_MASK = (1<<7),    /*!< GPIO Pin PTI7 bit mask */
} GPIO_PinMaskType;
其中每一个 1 << 31位的赋值都会出警告,请问如何解决,谢谢!
jcx0324 发表于 2017-3-24 16:59 | 显示全部楼层
直接用宏定义
不想取名字 发表于 2017-10-13 12:16 | 显示全部楼层
楼主,你好。我用keil5,下载的时候提示 Error: Flash Download failed - "Cortex-M0+",请教怎么解决?
