[STM32F4] USART中DMA接收时一直请求中断,可能会是什么问题
875|2
 楼主| ast145 发表于 2016-3-16 10:27 | 显示全部楼层 |阅读模式
   stm32f407中USART1中使用DMA接收外设数据,数据传输方向为外设到内存,DMA接收串口数据,使能了传输一半和传输完成中断,但是现在问题是,cpu一直响应处理dma中断函数,其他的程序都都执行不了,请问大家可能会是什么问题?
  1. static void GPS_DMA_Config(void)
  3.         //??IO??????
  4.          GPIO_InitTypeDef GPIO_InitStructure;
  5.         //??DMA???
  6.         DMA_InitTypeDef DMA_InitStructure;
  7.   RCC_AHB1PeriphClockCmd(GPS_DMA_CLK, ENABLE);
  8.         DMA_Cmd(GPS_DMA_STREAM,DISABLE);
  9.         DMA_DeInit(DMA2_Stream5);
  10.         while ( DMA_GetCmdStatus(GPS_DMA_STREAM) != DISABLE );
  11.         DMA_InitStructure.DMA_Channel = DMA_Channel_4;
  12.         //????
  13.         DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&USART1->DR);
  14.         //????
  15.         DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)gps_rbuff;      //´Ë´¦½ÓÊÕµØÖ·¿ÉÄÜÒª¸Ä
  16.         //dma????
  17.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  18.         //??DMA??????????
  19.         DMA_InitStructure.DMA_BufferSize = GPS_RBUFF_SIZE;                     //»º³åÊý¾Ý´óСÐèÒªÐÞ¸Ä
  20.         //??DMA???????,????
  21.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  22.         //??DMA???????
  23.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  24.         //??????
  25.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  26.         //??????
  27.         DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Byte;
  28.         //??DMA?????
  29.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  30.         //??DMA?????
  31.         DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
  32.
  33.         //????FIFO?????????????? : ???FIFO??
  34.         DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  35.         //???FIFO????
  36.         DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
  37.         //???Burst????????
  38.         DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  39.         //???Burst???????? */
  40.         DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  41.
  42.         DMA_Init(GPS_DMA_STREAM, &DMA_InitStructure);
  43.
  44.         GPS_Interrupt_Config();
  45.
  46.         DMA_ITConfig(GPS_DMA_STREAM,DMA_IT_HT | DMA_IT_TC ,ENABLE);
  47.   DMA_Cmd (GPS_DMA_STREAM,ENABLE);
  48.
  49.         USART_DMACmd(GPS_USART, USART_DMAReq_Rx, ENABLE);
  50.
  51. }
  52. void GPS_Config(u32 br_num)
  53. {
  54.          Usart1_Init(br_num);
  55.           GPS_DMA_Config();
  56. }
  1. //´Ë´¦ÅäÖõÄUSART1ûÓпªÖжÏʹÄÜ£¬ÓÃÓÚDMA½ÓÊÕ
  2. void Usart1_Init(u32 br_num)
  3. {
  4.         USART_InitTypeDef USART_InitStructure;
  5.         USART_ClockInitTypeDef USART_ClockInitStruct;
  6.         NVIC_InitTypeDef NVIC_InitStructure;
  7.         GPIO_InitTypeDef GPIO_InitStructure;
  8.
  9.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); //¿ªÆôUSART1ʱÖÓ
  10.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
  11.
  12.         //´®¿ÚÖжÏÓÅÏȼ¶
  13.         NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  14.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
  15.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  16.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  17.         NVIC_Init(&NVIC_InitStructure);
  18.
  19.         GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
  20.   GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
  21.
  22.         //ÅäÖÃPA9×÷ΪUSART1¡¡Tx
  23.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  24.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  25.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  26.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  27.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
  28.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  29.         //ÅäÖÃPA10×÷ΪUSART1¡¡Rx
  30.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 ;
  31.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  32.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  33.   GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
  34.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  35.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  36.
  37.         //ÅäÖÃUSART1
  38.         //Öжϱ»ÆÁ±ÎÁË
  39.         USART_InitStructure.USART_BaudRate = br_num;       //²¨ÌØÂÊ¿ÉÒÔͨ¹ýµØÃæÕ¾ÅäÖÃ
  40.         USART_InitStructure.USART_WordLength = USART_WordLength_8b;  //8λÊý¾Ý
  41.         USART_InitStructure.USART_StopBits = USART_StopBits_1;   //ÔÚÖ¡½áβ´«Êä1¸öֹͣλ
  42.         USART_InitStructure.USART_Parity = USART_Parity_No;    //½ûÓÃÆæÅ¼Ð£Ñé
  43.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //Ó²¼þÁ÷¿ØÖÆÊ§ÄÜ
  44.         USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;  //·¢ËÍ¡¢½ÓÊÕʹÄÜ
  45.         //ÅäÖÃUSART1ʱÖÓ
  46.         USART_ClockInitStruct.USART_Clock = USART_Clock_Disable;  //ʱÖÓµÍµçÆ½»î¶¯
  47.         USART_ClockInitStruct.USART_CPOL = USART_CPOL_Low;  //SLCKÒý½ÅÉÏʱÖÓÊä³öµÄ¼«ÐÔ->µÍµçƽ
  48.         USART_ClockInitStruct.USART_CPHA = USART_CPHA_2Edge;  //ʱÖÓµÚ¶þ¸ö±ßÑØ½øÐÐÊý¾Ý²¶»ñ
  49.         USART_ClockInitStruct.USART_LastBit = USART_LastBit_Disable; //×îºóһλÊý¾ÝµÄʱÖÓÂö³å²»´ÓSCLKÊä³ö
  50.
  51.         USART_Init(USART1, &USART_InitStructure);
  52.         USART_ClockInit(USART1, &USART_ClockInitStruct);
  53.         //ʹÄÜUSART1½ÓÊÕÖжÏ
  54.         //USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  55.         //ʹÄÜUSART1
  56.         USART_Cmd(USART1, ENABLE);
  57. //        //ʹÄÜ·¢ËÍ£¨½øÈëÒÆÎ»£©ÖжÏ
  58. //        if(!(USARTQ->CR1 & USART_CR1_TXEIE))
  59. //        {
  60. //                USART_ITConfig(USARTQ, USART_IT_TXE, ENABLE);
  61. //        }
  62. }
下面是中断处理函数,中断程序函数名和重写了,现在问题就是程序出中断,进中断,始终执行这个中断函数
  1. void GPS_ProcessDMAIRQ(void)
  4.   if(DMA_GetITStatus(GPS_DMA_STREAM,GPS_DMA_IT_HT) )
  5.   {
  6.     GPS_HalfTransferEnd = 1;
  7. DMA_ClearFlag(DMA2_Stream5,DMA_FLAG_HTIF5);
  8.   }
  9. if(DMA_GetITStatus(GPS_DMA_STREAM,GPS_DMA_IT_TC))
  10.   {
  11.     GPS_TransferEnd = 1;
  12.                 DMA_ClearFlag(DMA2_Stream5,DMA_FLAG_TCIF5);
  13.    }
  14.
  15. }
yklstudent 发表于 2016-3-16 12:49 | 显示全部楼层
在线跑下,看下DMA状态寄存器的情况
 楼主| ast145 发表于 2016-3-16 13:26 | 显示全部楼层
DMA状态寄存器都没有问题,原因找到了,堆设置的太小了,默认值是0x0400,现在改为0x1000就可以了,我DMA缓冲区设置的512个字节,可能堆区设置的不够大
