| #include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
uchar temp,num,bai,shi,ge;
uchar key[]={0x3f,0x5f,0x6f};
uchar code table[]=
0x3f , 0x06 , 0x5b ,
0x4f , 0x66 , 0x6d ,
0x7d , 0x07 , 0x7f ,
0x6f };
void keyscan();
void delay(uchar z);
void dsp(uchar bai,uchar shi,uchar ge);
void main()
 while(1)
    keyscan();
    dsp(bai,shi,ge);
void delay(uchar z)
 uchar x,y;
 for(x=100;x--;x>0)
  for(y=z;y--;y>0);
   bai=num/100;
   shi=num%100/10;
   ge=num%10;
   P0=0xfb;
   P2=table[bai];
   delay(1);
   P0=0xfd;
   P2=table[shi];
   delay(1);
   P0=0xfe;
   P2=table[ge];
   delay(1);
void keyscan()
{   uchar i;
 for(i=0;i<3;i++)
     P1=key[i];
     temp=P1;
     temp&=0x0f;
     if(temp!=0x0f) //如果有键按下
      delay(5);
   temp=P1;
      temp&=0x0f;
   if(temp!=0x0f)//确实有键按下
     switch(temp)
      case 0x07:switch(i)
            case 0:num=1;break;
            case 1:num=5;break;
            case 2:num=9;break;
      break;
      case 0x0b:switch(i)
            case 0:num=2;break;
            case 1:num=6;break;
            case 2:num=10;break;
      break;
      case 0x0d:switch(i)
            case 0:num=3;break;
            case 1:num=7;break;
            case 2:num=11;break;
      break;
      case 0x0e:switch(i)
            case 0:num=4;break;
            case 1:num=8;break;
            case 2:num=12;break;
      break;
      while(temp!=0xf0) //松开手后就跳出循环,否则等待松手
      temp=P1;
      temp=temp&0xf0;
      dsp(bai,shi,ge);
