- #ifndef _COM_BUFFERED_H_
- #define _COM_BUFFERED_H_
- #define COM1 0
- #define COM2 1
- #define COM_RX_BUF_SIZE 64 /* Number of characters in Rx ring buffer */
- #define COM_TX_BUF_SIZE 64 /* Number of characters in Tx ring buffer */
- #define COM_NO_ERR 0 /* Function call was successful */
- #define COM_BAD_CH 1 /* Invalid communications port channel */
- #define COM_RX_EMPTY 2 /* Rx buffer is empty, no character available */
- #define COM_TX_FULL 3 /* Tx buffer is full, could not deposit character */
- #define COM_TX_EMPTY 4 /* If the Tx buffer is empty. */
- * function : COMGetCharB
- * parameter: char port, port can be COM1 / COM2
- * parameter: char* err is a pointer to where an error code will be placed:
- * *err is set to COM_NO_ERR if a character is available
- * *err is set to COM_RX_EMPTY if the Rx buffer is empty
- * *err is set to COM_BAD_CH if you have specified an invalid channel
- * return : char
- * usage : This function is called by your application to obtain a character from the communications
- * channel.
- * changelog:
- unsigned char COMGetCharB (unsigned char ch, unsigned char *err);
- * function : COMPutCharB
- * return : COMM_NO_ERR if the function was successful (the buffer was not full)
- * COMM_TX_FULL if the buffer was full
- * COMM_BAD_CH if you have specified an incorrect channel
- * usage : This function is called by your application to send a character on the communications
- * channel. The character to send is first inserted into the Tx buffer and will be sent by
- * the Tx ISR. If this is the first character placed into the buffer, the Tx ISR will be
- * enabled. If the Tx buffer is full, the character will not be sent (i.e. it will be lost)
- * changelog:
- unsigned char COMPutCharB (unsigned char port, unsigned char c);
- * function : COMBufferInit
- * parameter:
- * return :
- * usage : This function is called by your application to initialize the communications module. You
- * must call this function before calling any other functions.
- * changelog:
- void COMBufferInit (void);
- * function : COMBufferIsEmpty
- * return : char
- * usage : This function is called by your application to see
- * if any character is available from the communications channel.
- * If at least one character is available, the function returns
- * FALSE(0) otherwise, the function returns TRUE(1).
- * changelog:
- unsigned char COMBufferIsEmpty (unsigned char port);
- * function : COMBufferIsFull
- * return : char
- * usage : This function is called by your application to see if any more characters can be placed
- * in the Tx buffer. In other words, this function check to see if the Tx buffer is full.
- * If the buffer is full, the function returns TRUE otherwise, the function returns FALSE.
- * changelog:
- unsigned char COMBufferIsFull (unsigned char port);
- #endif
- * file: com_buffered.c
- * author: Li Yuan
- * platform: STM32F107
- * date: 2013-5-5
- * version: 0.0.1
- * description: UART Ring Buffer
- #include "stm32f10x_usart.h"
- #include "com_buffered.h"
- #define OS_ENTER_CRITICAL() __set_PRIMASK(1)
- #define OS_EXIT_CRITICAL() __set_PRIMASK(0)
- * Enables Transmiter interrupt.
- static void COMEnableTxInt(unsigned char port)
- static USART_TypeDef* map[2] = {USART1, USART2};
- USART_ITConfig(map[port], USART_IT_TXE, ENABLE);
- * DATA TYPES
- typedef struct {
- short RingBufRxCtr; /* Number of characters in the Rx ring buffer */
- unsigned char *RingBufRxInPtr; /* Pointer to where next character will be inserted */
- unsigned char *RingBufRxOutPtr; /* Pointer from where next character will be extracted */
- unsigned char RingBufRx[COM_RX_BUF_SIZE]; /* Ring buffer character storage (Rx) */
- short RingBufTxCtr; /* Number of characters in the Tx ring buffer */
- unsigned char *RingBufTxInPtr; /* Pointer to where next character will be inserted */
- unsigned char *RingBufTxOutPtr; /* Pointer from where next character will be extracted */
- unsigned char RingBufTx[COM_TX_BUF_SIZE]; /* Ring buffer character storage (Tx) */
- } COM_RING_BUF;
- * GLOBAL VARIABLES
- COM_RING_BUF COM1Buf;
- COM_RING_BUF COM2Buf;
- * return : char
- * channel.
- * changelog:
- unsigned char COMGetCharB (unsigned char port, unsigned char *err)
- // unsigned char cpu_sr;
- unsigned char c;
- COM_RING_BUF *pbuf;
- switch (port)
- { /* Obtain pointer to communications channel */
- case COM1:
- pbuf = &COM1Buf;
- break;
- case COM2:
- pbuf = &COM2Buf;
- break;
- default:
- *err = COM_BAD_CH;
- return (0);
- OS_ENTER_CRITICAL();
- if (pbuf->RingBufRxCtr > 0) /* See if buffer is empty */
- pbuf->RingBufRxCtr--; /* No, decrement character count */
- c = *pbuf->RingBufRxOutPtr++; /* Get character from buffer */
- if (pbuf->RingBufRxOutPtr == &pbuf->RingBufRx[COM_RX_BUF_SIZE])
- pbuf->RingBufRxOutPtr = &pbuf->RingBufRx[0]; /* Wrap OUT pointer */
- OS_EXIT_CRITICAL();
- *err = COM_NO_ERR;
- return (c);
- } else {
- *err = COM_RX_EMPTY;
- c = 0; /* Buffer is empty, return 0 */
- return (c);
- * changelog:
- * 1.first implimented by liyuan 2010.11.5
- switch (port)
- case COM1:
- pbuf = &COM1Buf;
- break;
- case COM2:
- pbuf = &COM2Buf;
- break;
- default:
- return (COM_BAD_CH);
- if (pbuf->RingBufTxCtr < COM_TX_BUF_SIZE) { /* See if buffer is full */
- pbuf->RingBufTxCtr++; /* No, increment character count */
- *pbuf->RingBufTxInPtr++ = c; /* Put character into buffer */
- if (pbuf->RingBufTxInPtr == &pbuf->RingBufTx[COM_TX_BUF_SIZE]) { /* Wrap IN pointer */
- pbuf->RingBufTxInPtr = &pbuf->RingBufTx[0];
- if (pbuf->RingBufTxCtr == 1) { /* See if this is the first character */
- COMEnableTxInt(port); /* Yes, Enable Tx interrupts */
- } else {
- return (COM_NO_ERR);
- } else {
- return (COM_TX_FULL);
- * parameter:
- * return :
- * changelog:
- pbuf = &COM1Buf; /* Initialize the ring buffer for COM0 */
- pbuf->RingBufRxCtr = 0;
- pbuf->RingBufRxInPtr = &pbuf->RingBufRx[0];
- pbuf->RingBufTxCtr = 0;
- pbuf->RingBufTxOutPtr = &pbuf->RingBufTx[0];
- pbuf = &COM2Buf; /* Initialize the ring buffer for COM1 */
- * return : char
- * changelog:
- unsigned char empty;
- switch (port)
- case COM1:
- pbuf = &COM1Buf;
- break;
- case COM2:
- pbuf = &COM2Buf;
- break;
- default:
- return (1);
- { /* See if buffer is empty */
- empty = 0; /* Buffer is NOT empty */
- else
- empty = 1; /* Buffer is empty */
- return (empty);
- * return : char
- * changelog:
- char full;
- switch (port)
- case COM1:
- pbuf = &COM1Buf;
- break;
- case COM2:
- pbuf = &COM2Buf;
- break;
- default:
- return (1);
- full = 0; /* Buffer is NOT full */
- } else {
- full = 1; /* Buffer is full */
- return (full);
- // This function is called by the Rx ISR to insert a character into the receive ring buffer.
- static void COMPutRxChar (unsigned char port, unsigned char c)
- switch (port)
- case COM1:
- pbuf = &COM1Buf;
- break;
- case COM2:
- pbuf = &COM2Buf;
- break;
- default:
- return;
- if (pbuf->RingBufRxCtr < COM_RX_BUF_SIZE) { /* See if buffer is full */
- pbuf->RingBufRxCtr++; /* No, increment character count */
- *pbuf->RingBufRxInPtr++ = c; /* Put character into buffer */
- if (pbuf->RingBufRxInPtr == &pbuf->RingBufRx[COM_RX_BUF_SIZE]) { /* Wrap IN pointer */
- // This function is called by the Tx ISR to extract the next character from the Tx buffer.
- // The function returns FALSE if the buffer is empty after the character is extracted from
- // the buffer. This is done to signal the Tx ISR to disable interrupts because this is the
- // last character to send.
- static unsigned char COMGetTxChar (unsigned char port, unsigned char *err)
- unsigned char c;
- switch (port)
- case COM1:
- pbuf = &COM1Buf;
- break;
- case COM2:
- pbuf = &COM2Buf;
- break;
- default:
- return (0);
- if (pbuf->RingBufTxCtr > 0) { /* See if buffer is empty */
- pbuf->RingBufTxCtr--; /* No, decrement character count */
- c = *pbuf->RingBufTxOutPtr++; /* Get character from buffer */
- if (pbuf->RingBufTxOutPtr == &pbuf->RingBufTx[COM_TX_BUF_SIZE])
- pbuf->RingBufTxOutPtr = &pbuf->RingBufTx[0]; /* Wrap OUT pointer */
- return (c); /* Characters are still available */
- } else {
- *err = COM_TX_EMPTY;
- return (0); /* Buffer is empty */
- void USART1_IRQHandler(void)
- unsigned int data;
- unsigned char err;
- if(USART1->SR & 0x0F)
- // See if we have some kind of error
- // Clear interrupt (do nothing about it!)
- data = USART1->DR;
- else if(USART1->SR & USART_FLAG_RXNE) //Receive Data Reg Full Flag
- COMPutRxChar(COM1, data); // Insert received character into buffer
- else if(USART1->SR & USART_FLAG_TXE)
- data = COMGetTxChar(COM1, &err); // Get next character to send.
- if (err == COM_TX_EMPTY)
- { // Do we have anymore characters to send ?
- // No, Disable Tx interrupts
- //USART_ITConfig(USART1, USART_IT_TXE| USART_IT_TC, ENABLE);
- USART1->CR1 &= ~USART_FLAG_TXE | USART_FLAG_TC;
- else
- USART1->DR = data; // Yes, Send character
- void USART2_IRQHandler(void)
- if(USART2->SR & 0x0F)
- data = USART2->DR;
- else if(USART2->SR & USART_FLAG_RXNE) //Receive Data Reg Full Flag
- COMPutRxChar(COM2, data); // Insert received character into buffer
- else if(USART2->SR & USART_FLAG_TXE)
- data = COMGetTxChar(COM2, &err); // Get next character to send.
- //USART_ITConfig(USART2, USART_IT_TXE| USART_IT_TC, ENABLE);
- USART2->CR1 &= ~USART_FLAG_TXE | USART_FLAG_TC;
- else
- USART2->DR = data; // Yes, Send character
