| 不是虚拟机,主机14.04ubuntu *64 库文件安装没有问题 执行./ltib失败问题描述如下
 Processing platform: Host support packages
 using /home/jute/my_imx28/L2.6.35_1.1.0_130130_source/source/ltib/config/platform/host/ltib.preconfig
 Processing: fake-provides
 Processing: mkspooflinks
 Processing: distcc
 Processing: ccache
 Processing: bison
 Processing: flex
 Processing: texinfo
 Processing: autoconf
 Processing: libtool
 Processing: lkc
 Build path taken because: no prebuilt rpm,
 rpmbuild --dbpath ///opt/freescale/ltib/var/lib/rpm --target x86_64 --define '_unpackaged_files_terminate_build 0' --define '_target_cpu x86_64' --define '__strip strip' --define '_topdir /opt/freescale/ltib/usr/src/rpm' --define '_prefix /opt/freescale/ltib/usr' --define '_tmppath /home/jute/my_imx28/L2.6.35_1.1.0_130130_source/source/ltib/tmp' --define '_rpmdir /opt/freescale/ltib/usr/src/rpm/RPMS'  --define '_mandir /opt/freescale/ltib/usr/share/man' --define '_sysconfdir /opt/freescale/ltib/etc' --define '_localstatedir /var' -bb --clean --rmsource  /home/jute/my_imx28/L2.6.35_1.1.0_130130_source/source/ltib/dist/lfs-5.1/lkc/lkc.spec
 Building target platforms: x86_64
 Building for target x86_64
 Executing(%prep): /bin/sh -e /home/jute/my_imx28/L2.6.35_1.1.0_130130_source/source/ltib/tmp/rpm-tmp.30877
 + umask 022
 + cd /opt/freescale/ltib/usr/src/rpm/BUILD
 + rm -rf lkc-1.4
 + /bin/gzip -dc /opt/freescale/ltib/usr/src/rpm/SOURCES/lkc-1.4.tar.gz
 + tar -xvvf -
 drwxr-sr-x roman/users       0 2003-06-16 01:21 lkc-1.4/
 -rw-r--r-- roman/users    5167 2003-06-01 06:13 lkc-1.4/Makefile
 -rw-r--r-- roman/users    3805 2003-03-16 01:05 lkc-1.4/Makefile.kernel
 -rw-r--r-- roman/users     734 2002-10-21 03:01 lkc-1.4/README
 -rw-r--r-- roman/users   10369 2003-06-07 06:00 lkc-1.4/conf.c
 -rw-r--r-- roman/users    8878 2003-06-04 08:12 lkc-1.4/confdata.c
 drwxr-sr-x roman/users       0 2002-10-21 03:05 lkc-1.4/example/
 -rw-r--r-- roman/users     536 2002-10-21 02:45 lkc-1.4/example/miniconf.rb
 -rw-r--r-- roman/users     804 2002-10-21 02:45 lkc-1.4/example/query.rb
 -rw-r--r-- roman/users   25007 2003-05-13 02:49 lkc-1.4/expr.c
 -rw-r--r-- roman/users    4890 2003-05-17 02:05 lkc-1.4/expr.h
 -rw-r--r-- roman/users     103 2002-10-20 22:41 lkc-1.4/extconf.rb
 -rw-r--r-- roman/users   40325 2003-06-02 04:45 lkc-1.4/gconf.c
 -rw-r--r-- roman/users   20978 2003-03-15 22:00 lkc-1.4/gconf.glade
 -rw-r--r-- roman/users    6565 2003-03-15 22:00 lkc-1.4/images.c
 -rw-r--r-- roman/users    2770 2002-12-09 00:12 lkc-1.4/kconfig.i
 -rw-r--r-- roman/users     644 2002-10-28 04:22 lkc-1.4/kconfig_load.c
 -rw-r--r-- roman/users    9438 2003-06-01 06:09 lkc-1.4/lkc-language.txt
 -rw-r--r-- roman/users    2739 2003-05-25 10:18 lkc-1.4/lkc.h
 -rw-r--r-- roman/users    1619 2003-05-26 07:23 lkc-1.4/lkc_proto.h
 -rw-r--r-- roman/users   17302 2003-05-29 05:02 lkc-1.4/mconf.c
 -rw-r--r-- roman/users   10243 2003-06-05 05:47 lkc-1.4/menu.c
 -rw-r--r-- roman/users   30879 2003-06-16 01:21 lkc-1.4/qconf.cc
 -rw-r--r-- roman/users    5218 2003-04-21 07:53 lkc-1.4/qconf.h
 -rw-r--r-- roman/users   15613 2003-06-07 06:00 lkc-1.4/symbol.c
 -rw-r--r-- roman/users    7173 2003-05-27 02:21 lkc-1.4/zconf.l
 -rw-r--r-- roman/users   14637 2003-05-27 02:21 lkc-1.4/zconf.y
 + STATUS=0
 + [ 0 -ne 0 ]
 + cd lkc-1.4
 + echo Patch #0 (lkc-1.4-lxdialog.patch):
 + patch -p1 -s
 + echo Patch #1 (lkc-1.4-1.patch):
 + patch -p1 -s
 + echo Patch #2 (lkc-1.4-ncurses.patch):
 + patch -p1 -s
 + echo Patch #3 (lkc-1.4-help.patch):
 + patch -p1 -s
 + echo Patch #4 (lkc-1.4-defaults-4.patch):
 + patch -p1 -s
 + echo Patch #5 (lkc-1.4-search-5.patch):
 + patch -p1 -s
 + echo Patch #6 (lkc-1.4-datestamp.patch):
 + patch -p1 -s
 + echo Patch #7 (lkc-1.4-dashsource.patch):
 + patch -p1 -s
 + echo Patch #8 (lkc-1.4-config_title-1.patch):
 + patch -p1 -s
 + echo Patch #9 (lkc-1.4-config_filename-1.patch):
 + patch -p1 -s
 + exit 0
 Executing(%build): /bin/sh -e /home/jute/my_imx28/L2.6.35_1.1.0_130130_source/source/ltib/tmp/rpm-tmp.30877
 + umask 022
 + cd lkc-1.4
 + make -j1 conf mconf
 gcc -O0 -Wall -g -fPIC -c conf.c -o conf.o
 conf.c: In function 'conf_string':
 conf.c:163:20: warning: variable 'help' set but not used [-Wunused-but-set-variable]
 const char *def, *help;
 conf.c: In function 'conf_sym':
 conf.c:197:6: warning: variable 'type' set but not used [-Wunused-but-set-variable]
 int type;
 conf.c: In function 'conf_choice':
 conf.c:272:6: warning: variable 'type' set but not used [-Wunused-but-set-variable]
 int type;
 bison -l -b zconf -p zconf zconf.y
 flex -L -Pzconf zconf.l
 gcc -O0 -Wall -g -fPIC -c zconf.tab.c -o zconf.tab.o
 In file included from zconf.tab.c:2498:0:
 lex.zconf.c:3075:16: warning: 'input' defined but not used [-Wunused-function]
 static int input  (void)
 gcc  conf.o zconf.tab.o -o conf
 gcc -O0 -Wall -g -fPIC -c mconf.c -o mconf.o
 mconf.c: In function 'search_page_dialog':
 mconf.c:396:2: warning: pointer targets in passing argument 2 of 'strncpy' differ in signedness [-Wpointer-sign]
 strncpy(search_page_pattern, dialog_input_result, sizeof(search_page_pattern));
 In file included from mconf.c:22:0:
 /usr/include/string.h:132:14: note: expected 'const char * __restrict__' but argument is of type 'unsigned char *'
 extern char *strncpy (char *__restrict __dest,
 mconf.c: In function 'search_conf':
 mconf.c:421:2: warning: pointer targets in passing argument 1 of 'sym_re_search' differ in signedness [-Wpointer-sign]
 sym_arr = sym_re_search(dialog_input_result);
 In file included from mconf.c:31:0:
 lkc_proto.h:23:3: note: expected 'const char *' but argument is of type 'unsigned char *'
 P(sym_re_search,struct symbol **,(const char *pattern));
 lkc.h:16:38: note: in definition of macro 'P'
 #define P(name,type,arg) extern type name arg
 mconf.c: In function 'conf_string':
 mconf.c:937:4: warning: pointer targets in passing argument 2 of 'sym_set_string_value' differ in signedness [-Wpointer-sign]
 if (sym_set_string_value(menu->sym, dialog_input_result))
 lkc_proto.h:33:3: note: expected 'const char *' but argument is of type 'unsigned char *'
 P(sym_set_string_value,bool,(struct symbol *sym, const char *newval));
 mconf.c: In function 'conf_load':
 mconf.c:958:4: warning: pointer targets in passing argument 1 of 'conf_read' differ in signedness [-Wpointer-sign]
 if (!conf_read(dialog_input_result))
 lkc_proto.h:4:3: note: expected 'const char *' but argument is of type 'unsigned char *'
 P(conf_read,int,(const char *name));
 mconf.c: In function 'conf_save':
 mconf.c:979:4: warning: pointer targets in passing argument 1 of 'conf_write' differ in signedness [-Wpointer-sign]
 if (!conf_write(dialog_input_result))
 lkc_proto.h:5:3: note: expected 'const char *' but argument is of type 'unsigned char *'
 P(conf_write,int,(const char *name));
 mconf.c: At top level:
 mconf.c:33:13: warning: 'menu_backtitle' defined but not used [-Wunused-variable]
 static char menu_backtitle[128];
 cd lxdialog && make
 make[1]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/lkc-1.4/lxdialog'
 gcc  -DCURSES_LOC="<ncurses.h>" -I. -c checklist.c -o checklist.o
 gcc  -DCURSES_LOC="<ncurses.h>" -I. -c menubox.c -o menubox.o
 gcc  -DCURSES_LOC="<ncurses.h>" -I. -c textbox.c -o textbox.o
 gcc  -DCURSES_LOC="<ncurses.h>" -I. -c yesno.c -o yesno.o
 gcc  -DCURSES_LOC="<ncurses.h>" -I. -c inputbox.c -o inputbox.o
 gcc  -DCURSES_LOC="<ncurses.h>" -I. -c util.c -o util.o
 gcc  -DCURSES_LOC="<ncurses.h>" -I. -c msgbox.c -o msgbox.o
 ar rc lxdialog.a checklist.o menubox.o textbox.o yesno.o inputbox.o util.o msgbox.o
 ranlib lxdialog.a
 make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/lkc-1.4/lxdialog'
 gcc  -lncurses mconf.o zconf.tab.o lxdialog/lxdialog.a -o mconf
 lxdialog/lxdialog.a(checklist.o): In function `print_item':
 checklist.c:(.text+0x42): undefined reference to `wmove'
 checklist.c:(.text+0x5c): undefined reference to `waddch'
 checklist.c:(.text+0x82): undefined reference to `wmove'
 checklist.c:(.text+0xdc): undefined reference to `wprintw'
 checklist.c:(.text+0x108): undefined reference to `wprintw'
 checklist.c:(.text+0x144): undefined reference to `wmove'
 checklist.c:(.text+0x163): undefined reference to `waddch'
 checklist.c:(.text+0x1a4): undefined reference to `waddnstr'
 checklist.c:(.text+0x1c4): undefined reference to `wmove'
 checklist.c:(.text+0x1d0): undefined reference to `wrefresh'
 lxdialog/lxdialog.a(checklist.o): In function `print_arrows':
 checklist.c:(.text+0x203): undefined reference to `wmove'
 checklist.c:(.text+0x226): undefined reference to `acs_map'
 checklist.c:(.text+0x235): undefined reference to `waddch'
 checklist.c:(.text+0x24b): undefined reference to `waddnstr'
 checklist.c:(.text+0x26a): undefined reference to `acs_map'
 checklist.c:(.text+0x279): undefined reference to `waddch'
 checklist.c:(.text+0x280): undefined reference to `acs_map'
 checklist.c:(.text+0x28f): undefined reference to `waddch'
 checklist.c:(.text+0x296): undefined reference to `acs_map'
 checklist.c:(.text+0x2a5): undefined reference to `waddch'
 checklist.c:(.text+0x2ac): undefined reference to `acs_map'
 checklist.c:(.text+0x2bb): undefined reference to `waddch'
 checklist.c:(.text+0x2dd): undefined reference to `wmove'
 checklist.c:(.text+0x314): undefined reference to `acs_map'
 checklist.c:(.text+0x323): undefined reference to `waddch'
 checklist.c:(.text+0x339): undefined reference to `waddnstr'
 checklist.c:(.text+0x358): undefined reference to `acs_map'
 util.c:(.text+0xa33): undefined reference to `has_colors'
 util.c:(.text+0xa6d): undefined reference to `wmove'
 util.c:(.text+0xa82): undefined reference to `winch'
 util.c:(.text+0xa94): undefined reference to `waddch'
 util.c:(.text+0xac4): undefined reference to `wmove'
 util.c:(.text+0xad0): undefined reference to `winch'
 util.c:(.text+0xae2): undefined reference to `waddch'
 util.c:(.text+0xaee): undefined reference to `winch'
 util.c:(.text+0xb00): undefined reference to `waddch'
 util.c:(.text+0xb20): undefined reference to `wnoutrefresh'
 collect2: error: ld returned 1 exit status
 make: *** [mconf] Error 1
 error: Bad exit status from /home/jute/my_imx28/L2.6.35_1.1.0_130130_source/source/ltib/tmp/rpm-tmp.30877 (%build)
 RPM build errors:
 Build time for lkc: 1 seconds
 Failed building lkc
 Died at ./ltib line 1392.
 traceback:
 main::build_host_rpms:1392
 main::host_checks:1447
 main:554
 Started: Tue Apr 19 19:43:24 2016
 Ended:   Tue Apr 19 19:43:31 2016
 Elapsed: 7 seconds
 These packages failed to build:
 lkc
 Build Failed
