#define switch_all_LEDs_on { GPIOB->ODR|= ALL_LEDs; } //LEDs control : all on
#define switch_all_LEDs_off { GPIOB->ODR&=~ALL_LEDs; } //LEDs control : all off
/* Private variables ---------------------------------------------------------*/
u8 temp_AD_H; // temporary registers for reading ADC result (MSB)
u8 temp_AD_L; // temporary registers for reading ADC result (LSB)
u8 ADInit; // flag for ADC initialized
u8 ADSampRdy; // flag for filed of samples ready
u8 AD_samp; // counter of stored samples
u16 AD_sample[NUMB_SAMP]; // store samples field
u16 AD_avg_value; // average of ADC result
u8 peak_memo; // variables for peak level detector
u8 peak_filt; // variables for peak level detector*/
/* Private function prototypes -----------------------------------------------*/
* @brief Count average of samples stored in the u16 field
* @par Parameters:
* *p: pointer to the begin of the field
* smp: number of samples in the field
* @retval Average u16 value
u16 u16_average(u16 *p, u8 smp) {
u8 i;
u16 sum;
for(i=0, sum= 0; i < smp; ++i)
sum+= *p++;
return sum / smp;
* @brief Prepare data for four LED bar of signal and peak indicator
* @par Parameters:
* val: Level of the mesured signal [0-4]
* @retval 4 bits (low nibble) of the composite bar graph information
u8 signal_and_peak_level(u8 val) {
u8 signal;
u8 peak;
switch(val) {
case 0: peak= 0; signal= 0; break; //set peak and signal levels
case 1: peak= 1; signal= 1; break;
case 2: peak= 2; signal= 3; break;
case 3: peak= 4; signal= 7; break;
case 4: peak= 8; signal= 15; break;
default: peak= signal= 15;
if(peak_filt == 0) { // slow fall of peak level indicator
if(peak_memo) {
peak_memo>>= 1;
peak_filt= PEAK_FILTER;
else
--peak_filt;
if(peak >= peak_memo) { // check the highest level value
peak_memo= peak; // and copy it to peak indicator
peak_filt= PEAK_FILTER; // with fall speed refresh
return (signal | peak_memo); // return bar graph information
/* Public functions ----------------------------------------------------------*/
* @brief Validation firmware main entry point.
* @par Parameters:
* None
* @retval void None
void main(void) {
u8 leds;
// *** GPIO INIT ***
GPIOB->ODR&=~ALL_LEDs; // LEDs - as push-pull outputs, all off
GPIOB->DDR|= ALL_LEDs; //
GPIOB->CR1|= ALL_LEDs;
GPIOC->DDR|= 0x02; // PC.1 as push-pull outputs
GPIOC->CR1|= 0x02;
GPIOE->CR1&=~0x40; // PE.6 as a floating input
GPIOE->DDR&=~0x40;
// *** ADC INITIALIZATION ***
TIM1->ARRH= (u8)(AUTORELOAD >> 8); // set autoreload register for trigger period
TIM1->ARRL= (u8)(AUTORELOAD); //
TIM1->CCR1H= (u8)((AUTORELOAD-AD_STAB) >> 8); // set compare register for trigger period
TIM1->CCR1L= (u8)(AUTORELOAD-AD_STAB);
TIM1->CR1|= TIM1_CR1_ARPE; // auto reload register is buferred
TIM1->CR2= (4<<4) & TIM1_CR2_MMS; // CC1REF is used as TRGO
TIM1->CCMR1= (6<<4) & TIM1_CCMR_OCM; // CC1REF in PWM 1 mode
TIM1->IER|= TIM1_IER_CC1IE; // CC1 interrupt enable
TIM1->CCER1|= TIM1_CCER1_CC1P; // CC1 negative polarity
TIM1->CCER1|= TIM1_CCER1_CC1E; // CC1 output enable
TIM1->BKR|= TIM1_BKR_MOE;
TIM1->SMCR|= TIM1_SMCR_MSM; // synchronization of TRGO with ADC
TIM1->CR1|= TIM1_CR1_CEN; // timer 1 enable
ADC1->CSR= ADC1_CSR_EOCIE | (9 & ADC1_CSR_CH); // ADC EOC interrupt enable, channel 9
ADC1->CR1= 4<<4 & ADC1_CR1_SPSEL; // master clock/8, single conversion
ADC1->CR2= ADC1_CR2_EXTTRIG; // external trigger on timer 1 TRGO, left alignment
ADC1->TDRH= 2; // disable Schmitt trigger on AD input 9
ADC1->TDRL= 0; //
// init ADC variables
AD_samp= 0; // number of stored samples 0
ADInit= TRUE; // ADC initialized
ADSampRdy= FALSE; // No sample
ADC1->CR1|= ADC1_CR1_ADON; // ADC on
enableInterrupts(); // enable all interrupts
// *** MAIN LOOP ***
while (1) {
if (ADSampRdy == TRUE) { // field of ADC samples is ready?
AD_avg_value= u16_average(&AD_sample[0], AD_samp); // average of samples
u8 temp_AD_L;
u8 ADInit; // flag for the first conversion
u8 AD_samp; // counter of raugh samples
u16 AD_sample[NUMB_SAMP]; // store field of raugh samples
u16 AD_avg_value; // filtered ADC result
* @par Parameters:
u8 i;
u16 sum;
sum+= *p++;
return sum / smp;
* @par Parameters:
u8 signal;
u8 peak;
switch(val) {
if(peak_memo) {
peak_memo>>= 1;
else
--peak_filt;
return (signal | peak_memo); // composite bar graph information
* @brief ADC interrupt service
* @par Parameters:
* None
* @retval None
#ifdef _COSMIC_ @far@interrupt void ADC2_Interrupt (void) {
#else
void ADC2_Interrupt (void) interrupt 22 {
#endif
if(ADInit == FALSE && ADSampRdy == FALSE) {
temp_AD_H= ADC2->DRH; // read conversion result (MSB first!)
temp_AD_L= ADC2->DRL; // an store it to AD samples field
AD_sample[AD_samp]= ((u16)(temp_AD_H) << 2) | (temp_AD_L & 3);
if(++AD_samp >= NUMB_SAMP) // AD_smaple field is full?
ADSampRdy= TRUE; // YES - set field ready flag for main loop
else
ADInit= FALSE; // ignore sample, wait for next one
ADC2->CSR&=~ADC2_CSR_EOC; // clear end of conversion flag
return;
* @brief TIM1 compare 1 interrupt service
* @par Parameters:
* None
* @retval None
#ifdef _COSMIC_
@far @interrupt void TIM1CapCompInterrupt (void) {
#else
void TIM1CapCompInterrupt (void) interrupt 12 {
#endif
ADC2->CR1|= ADC2_CR1_ADON; // start waiting for the next conversion trigger
TIM1->SR1&=~TIM1_SR1_CC1IF; // clear compare flag
return;
* @par Parameters:
* None
* @retval void None
void main(void) {
u8 leds;
// *** GIO INIT ***
GPIOH->ODR&=~ALL_LEDs; // LEDs - as push-pull outputs, all off
GPIOH->DDR|= ALL_LEDs; //
GPIOH->CR1|= ALL_LEDs;
GPIOE->DDR&=~0x40;
TIM1->ARRH= (u8)(AUTORELOAD >> 8); // init sampling period and pulse wide
TIM1->ARRL= (u8)(AUTORELOAD); // auto reload register
TIM1->CCR1H= (u8)((AUTORELOAD-AD_STAB) >> 8);// compare register
TIM1->CCER1|= TIM1_CCER1_CC1P; // OC1 negative polarity
TIM1->CCER1|= TIM1_CCER1_CC1E; // OC1 output enable
ADC2->CSR= ADC2_CSR_EOCIE | (9 & ADC2_CSR_CH); // ADC EOC interrupt enable, channel 9
ADC2->CR1= 4<<4 & ADC2_CR1_SPSEL; // master clock/8, single conversion
ADC2->CR2= ADC2_CR2_EXTTRIG; // external trigger on timer 1 TRGO, left alignment
ADC2->TDRH= 2; // disable Schmitt trigger on AD input 9
ADC2->TDRL= 0;
while (1) {
AD_samp= 0; // start new ADC reading cycle
ADSampRdy= FALSE;
