2.6.30.10移植后的问题
2096|1
 楼主| 997522323 发表于 2010-1-16 12:05 | 显示全部楼层 |阅读模式
我移植后,终端打印出的信息:
Freeing init memory: 104K
mount: mounting none on /tmp failed: No such file or directory
hwclock: can't open '/dev/misc/rtc': No such file or directory
/etc/rc.d/init.d/netd: line 16: /usr/sbin/inetd: not found
/etc/rc.d/init.d/httpd: line 16: /usr/sbin/boa: not found
/etc/rc.d/init.d/leds: line 16: /usr/bin/led-player: not found
板子是s3c2440,而且没有画面,确切的说是有振动的看不清画面,我用的是友善的开发板,请高手指点
Fe_ARM 发表于 2010-1-16 19:32 | 显示全部楼层
根据提示RTC\NET\LED这些都没与具体硬件驱动相关联上
