tq2440 ads
4622|6
 楼主| huanuo 发表于 2010-1-25 18:21 | 显示全部楼层 |阅读模式
刚买的tq2440开发板,为什么ads裸机测试的时候显示找不到文件啊。程序代码都是复制光盘上的。
Could not find or load the file ?440init.s?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file ?440slib.s?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file 襫and.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file ?440lib.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file 襇ain.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file 襪mu.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file 襠ma.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file 褹dc.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file 襝amif.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file 襝amproset.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file 襡eprom.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
Could not find or load the file 襂IC.c?for target 褼ebugRel?for project 襎Q2440_Test.mcp?
myitlover 发表于 2010-1-25 20:00 | 显示全部楼层
ads不支持中文路径,看看是不是用了中文的路径
还有你在ads里按ctrl+‘-’,全部重新编译一遍看看
 楼主| huanuo 发表于 2010-1-25 20:15 | 显示全部楼层
感谢楼上回复。我没有加中文路径,全是英文的、
gooogleman 发表于 2010-1-25 22:28 | 显示全部楼层
像是ADS没有**。
 楼主| huanuo 发表于 2010-1-26 08:39 | 显示全部楼层
不是,已经**了。
不懂ARM 发表于 2010-6-5 13:29 | 显示全部楼层
是路径改变了,所有文件都要重新编译一下。Pretoct-->Remove Object Code...然后再重新编译一下就OK了.....
freewing 发表于 2010-9-20 12:19 | 显示全部楼层
恩,如果还有问题,可以直接上天嵌科技的论坛咨询,http://www.embedsky.net/bbs,或者电话咨询。
