好多人不知道怎么学编程,怎么学C语言,其实学习这些大牛厂商的头文件和库函数的风格,就可以了
/** Define GPIO Pin Data Input/Output. It could be used to control each I/O pin by pin address mapping.
* Example 1:
* P00 = 1;
* It is used to set P0.0 to high;
* Example 2:
* if (P00)
* P00 = 0;
* If P0.0 pin status is high, then set P0.0 data output to low.
#define GPIO_PIN_ADDR(port, pin) (*((volatile uint32_t *)((GPIO_PIN_DATA_BASE+(0x20*(port))) + ((pin)<<2))))
#define P00 GPIO_PIN_ADDR(0, 0) /*!< Specify P00 Pin Data Input/Output */
#define P01 GPIO_PIN_ADDR(0, 1) /*!< Specify P01 Pin Data Input/Output */
#define P02 GPIO_PIN_ADDR(0, 2) /*!< Specify P02 Pin Data Input/Output */
#define P03 GPIO_PIN_ADDR(0, 3) /*!< Specify P03 Pin Data Input/Output */
#define P04 GPIO_PIN_ADDR(0, 4) /*!< Specify P04 Pin Data Input/Output */
#define P05 GPIO_PIN_ADDR(0, 5) /*!< Specify P05 Pin Data Input/Output */
#define P06 GPIO_PIN_ADDR(0, 6) /*!< Specify P06 Pin Data Input/Output */
#define P07 GPIO_PIN_ADDR(0, 7) /*!< Specify P07 Pin Data Input/Output */
#define P10 GPIO_PIN_ADDR(1, 0) /*!< Specify P10 Pin Data Input/Output */
#define P11 GPIO_PIN_ADDR(1, 1) /*!< Specify P11 Pin Data Input/Output */
我们看到这注释也是很简单易懂的,先告诉你怎么用,然后再给您看具体这个是怎么实现的。
