[应用相关] IAR for 8051出错
994|0
 楼主| 新蓝兰 发表于 2016-6-2 15:55 | 显示全部楼层 |阅读模式
IAR, FOR, ic, ui, ST
自己建的工程,编译时显示错误Fatal Error[Pe035]: #error directive: "Chip not supported!" D:\IARfor 8051\点到点通信\user\include\hal_board.h 27
Error while running C/C++ Compiler
请问大神这是什么原因,要怎么解决?
#include "hal_board.h"
#include "hal_int.h"
#include "hal_mcu.h"
#include "hal_rf.h"
#include "basic_rf.h"
#include "LCD.h"
#define RF_CHANNEL 25
#define PAN_ID   0x2011
#define SWITCH_ADDR  0x2530
#define LIGHT_ADDR 0xBEEF
#define APP_PAYLOAD_LENGTH 1
#define LIGHT_TOGGLE_CMD  0
#define FAILED 0
//应用状态
#define IDLE 0
#define SEND_CMD 1
//应用角色
#define NONE 0
#define SWITCH 1
#define LIGHT 2
#define APP_MODES 2
//按键
#define HAL_BUTTON_1 1
#define  HAL_BUTTON_2 2
#define  HAL_BUTTON_3 3
#define  HAL_BUTTON_4 4
#define  HAL_BUTTON_5 5
#define HAL_BUTTON_6 6
static uint8 pTxData[APP_PAYLOAD_LENGTH];
static uint8 pRxData[APP_PAYLOAD_LENGTH];
static basicRfCfg_t basicRfConfig;
extern void halboardinit(void);
extern void ctrPCA9554FLASHLED(uint8 led);
extern void ctrPCA9554LED(uint8 led,uint8 operation);
extern uint8 halkeycmd(void);
#ifdef SECURITY_CCM
static uint8 key[]={
  0xc0,0xc1,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,
  0xc8,0xc9,0xca, 0xcb,0xcc,0xcd, 0xce,0xcf,
#endif
static void appLight();
static void appSwitch();
static uint8 appSelectMode(void);
/*函数名称:appLght*/
  basicRfConfig.myAddr=LIGHT_ADDR;
  if(basicRfInit(&basicRfConfig)==FAILED)
    ctrPCA9554FLASHLED(5);
basicRfReceiveOn();
//Main loop
while (TRUE)
  while(!basicRfPacketIsReady());
  if(basicRfReceive(pRxData,APP_PAYLOAD_LENGTH,NULL)>0)
    if(pRxData[0]==LIGHT_TOGGLE_CMD)
      ctrPCA9554FLASHLED(1);
/*appSwitch*/
  pTxData[0]=LIGHT_TOGGLE_CMD;
  basicRfConfig.myAddr=SWITCH_ADDR;
  basicRfReceiveOff();
  //Main loop
  while (TRUE)
    if(halkeycmd()==HAL_BUTTON_4)
        basicRfSendPacket(LIGHT_ADDR,pTxData,APP_PAYLOAD_LENGTH);
        halIntOff();
        halIntOn();
/*appSelectrMode*/
  uint8 key;
  GUI_ClearScreen();
  GUI_PutString5_7(25,6,"OURS-CC2530");
  GUI_PutString5_7(10,22,"Device Mode:");
  GUI_PutString5_7(10,35,"SW2->Light");
  GUI_PutString5_7(10,48,"SW3->Switch");
  LCM_Refresh();
  do
    key=halkeycmd();
  }while(key==HAL_BUTTON_1);
  if(key==HAL_BUTTON_2)
    GUI_ClearScreen();
    GUI_PutString5_7(10,35,"Light");
    LCM_Refresh();
    return LIGHT;
  if(key==HAL_BUTTON_3)
    GUI_ClearScreen();
    GUI_PutString5_7(10,35,"Switch");
    GUI_PutString5_7(10,48,"SW4 Send Command");
    LCM_Refresh();
    return SWITCH;
  return NONE;
/*main*/
void main(void)
  uint8 appMode=NONE;
  basicRfConfig.panId=PAN_ID;
  basicRfConfig.channel=RF_CHANNEL;
  basicRfConfig.ackRequest=TRUE;
#ifdef SECURITY_CCM
  basicRfConfig.securityKey=key;
#endif
  halboardinit();
  if(halRfInit()==FAILED)
  ctrPCA9554FLASHLED(6);
  GUI_PutString5_7(10,22,"Simple RF test");
  GUI_PutString5_7(10,35,"SW1->Start");
  LCM_Refresh();
  while(halkeycmd()!=HAL_BUTTON_1);
  halMcuWaitMs(350);
  appMode==appSelectMode();
  if(appMode==SWITCH)
    ctrPCA9554LED(2,1);
    appSwitch();
  else if(appMode==LIGHT)
    ctrPCA9554LED(3,1);
    appLight();
