- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.00
- * $Revision: 2 $
- * $Date: 15/10/12 8:13p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Demonstrate how to communicate with an off-chip SPI slave device.
- * This sample code needs to work with SPI_SlaveMode.
- * @note
- * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "Mini51Series.h"
- #define TEST_COUNT 16
- uint32_t g_au32SourceData[TEST_COUNT];
- uint32_t g_au32DestinationData[TEST_COUNT];
- volatile uint32_t g_u32TxDataCount;
- volatile uint32_t g_u32RxDataCount;
- volatile uint8_t g_u8Done;
- void SYS_Init(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System Clock */
- /* Set P5 multi-function pins for XTAL1 and XTAL2 */
- SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
- SYS->P5_MFP |= (SYS_MFP_P50_XTAL1 | SYS_MFP_P51_XTAL2);
- /* Enable external 12MHz XTAL, internal 22.1184MHz */
- CLK_EnableXtalRC(CLK_PWRCON_HXT|CLK_PWRCON_HIRC_EN_Msk);
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL_STB_Msk | CLK_CLKSTATUS_IRC22M_STB_Msk);
- /* Switch HCLK clock source to XTL */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_XTAL,CLK_CLKDIV_HCLK(1));
- /* STCLK to XTL STCLK to XTL */
- CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLK_S_XTAL);
- /* Enable IP clock */
- CLK_EnableModuleClock(UART_MODULE);
- CLK_EnableModuleClock(SPI_MODULE);
- /* Select IP clock source */
- CLK_SetModuleClock(UART_MODULE,CLK_CLKSEL1_UART_S_XTAL,CLK_CLKDIV_UART(1));
- /* Init I/O Multi-function */
- /* Set P0 multi-function pins for UART RXD and TXD */
- SYS->P0_MFP &= ~(SYS_MFP_P01_Msk | SYS_MFP_P00_Msk);
- SYS->P0_MFP |= (SYS_MFP_P01_RXD | SYS_MFP_P00_TXD);
- /* Setup SPI multi-function pin */
- SYS->P0_MFP |= SYS_MFP_P04_SPISS | SYS_MFP_P05_MOSI | SYS_MFP_P06_MISO | SYS_MFP_P07_SPICLK;
- /* Lock protected registers */
- SYS_LockReg();
- /* Update System Core Clock */
- SystemCoreClockUpdate();
- void UART_Init(void)
- /* Init UART */
- /* Reset IP */
- SYS_ResetModule(UART_RST);
- /* Configure UART and set UART Baudrate */
- UART_Open(UART, 115200);
- void SPI_Init(void)
- /* Init SPI */
- /* Configure as a master, clock idle low, falling clock edge Tx, rising edge Rx and 32-bit transaction */
- /* Set IP clock divider. SPI clock rate = 1MHz */
- SPI_Open(SPI, SPI_MASTER, SPI_MODE_0, 32, 1000000);
- /* Enable the automatic hardware slave select function. Select the SS pin and configure as low-active. */
- SPI_EnableAutoSS(SPI, SPI_SS, SPI_SS_ACTIVE_LOW);
- void SPI_IRQHandler(void)
- SPI_CLR_UNIT_TRANS_INT_FLAG(SPI0);
- g_u8Done = 1;
- int main(void)
- uint32_t u32DataCount, i;
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Init UART for printf */
- UART_Init();
- /* Init SPI */
- SPI_Init();
- printf("\n\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| SPI Driver Sample Code |\n");
- printf("\n");
- printf("Configure SPI as a master.\n");
- printf("SPI clock rate: %d Hz\n", SPI_GetBusClock(SPI0));
- for(u32DataCount=0; u32DataCount<TEST_COUNT; u32DataCount++) {
- g_au32SourceData[u32DataCount] = 0x00550000 + u32DataCount;
- g_au32DestinationData[u32DataCount] = 0;
- printf("Before starting the data transfer, make sure the slave device is ready. Press any key to start the transfer.\n");
- getchar();
- printf("\n");
- SPI_EnableInt(SPI0, SPI_IE_MASK);
- NVIC_EnableIRQ(SPI_IRQn);
- for(i=0; i<TEST_COUNT; i++) {
- g_u8Done = 0;
- SPI_WRITE_TX(SPI0, g_au32SourceData[i]);
- SPI_TRIGGER(SPI0);
- while(!g_u8Done);
- g_au32DestinationData[i] = SPI_READ_RX(SPI0);
- printf("Received data:\n");
- printf("%d:\t0x%08X\n", u32DataCount, g_au32DestinationData[u32DataCount]);
- printf("The data transfer was done.\n");
- while(1);
