- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V2.0
- * $Revision: 2 $
- * $Date: 14/12/25 10:24a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Monitor the conversion result of channel 2 by the digital compare function.
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M0518.h"
- #define PLL_CLOCK 50000000
- /* Define Function Prototypes */
- void SYS_Init(void);
- void UART0_Init(void);
- void AdcResultMonitorTest(void);
- /* Define global variables and constants */
- volatile uint32_t g_u32AdcCmp0IntFlag;
- volatile uint32_t g_u32AdcCmp1IntFlag;
- /* Init System Clock */
- /* Enable Internal RC 22.1184MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for external XTAL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Enable ADC module clock */
- CLK_EnableModuleClock(ADC_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
- /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
- CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
- /* Init I/O Multi-function */
- /* Set GPB multi-function pins for UART0 RXD and TXD */
- SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
- SYS->GPB_MFP |= SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
- /* Disable the GPA0 - GPA3 digital input path to avoid the leakage current. */
- GPIO_DISABLE_DIGITAL_PATH(PA, 0xF);
- /* Configure the GPA0 - GPA3 ADC analog input pins */
- SYS->GPA_MFP &= ~(SYS_GPA_MFP_PA0_Msk | SYS_GPA_MFP_PA1_Msk | SYS_GPA_MFP_PA2_Msk | SYS_GPA_MFP_PA3_Msk) ;
- SYS->GPA_MFP |= SYS_GPA_MFP_PA0_ADC0 | SYS_GPA_MFP_PA1_ADC1 | SYS_GPA_MFP_PA2_ADC2 | SYS_GPA_MFP_PA3_ADC3 ;
- /* Init UART */
- void UART0_Init()
- /* Reset IP */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* Function: AdcResultMonitorTest */
- /* Parameters: */
- /* None. */
- /* Returns: */
- /* None. */
- /* Description: */
- /* ADC result monitor function test. */
- void AdcResultMonitorTest()
- printf("\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| ADC compare function (result monitor) sample code |\n");
- printf("\nIn this test, software will compare the conversion result of channel 2.\n");
- /* Set the ADC operation mode as continuous scan, input mode as single-end and enable the analog input channel 2 */
- ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, 0x1 << 2);
- /* Power on ADC module */
- ADC_POWER_ON(ADC);
- /* Enable ADC comparator 0. Compare condition: conversion result < 0x800; match Count=5. */
- printf(" Set the compare condition of comparator 0: channel 2 is less than 0x800; match count is 5.\n");
- ADC_ENABLE_CMP0(ADC, 2, ADC_ADCMPR_CMPCOND_LESS_THAN, 0x800, 5);
- /* Enable ADC comparator 1. Compare condition: conversion result >= 0x800; match Count=5. */
- printf(" Set the compare condition of comparator 1: channel 2 is greater than or equal to 0x800; match count is 5.\n");
- ADC_ENABLE_CMP1(ADC, 2, ADC_ADCMPR_CMPCOND_GREATER_OR_EQUAL, 0x800, 5);
- /* Clear the ADC comparator 0 interrupt flag for safe */
- ADC_CLR_INT_FLAG(ADC, ADC_CMP0_INT);
- /* Enable ADC comparator 0 interrupt */
- ADC_EnableInt(ADC, ADC_CMP0_INT);
- /* Clear the ADC comparator 1 interrupt flag for safe */
- ADC_CLR_INT_FLAG(ADC, ADC_CMP1_INT);
- /* Enable ADC comparator 1 interrupt */
- ADC_EnableInt(ADC, ADC_CMP1_INT);
- NVIC_EnableIRQ(ADC_IRQn);
- g_u32AdcCmp0IntFlag = 0;
- g_u32AdcCmp1IntFlag = 0;
- /* Clear the ADC interrupt flag */
- ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
- /* Start A/D conversion */
- ADC_START_CONV(ADC);
- /* Wait ADC compare interrupt */
- while((g_u32AdcCmp0IntFlag == 0) && (g_u32AdcCmp1IntFlag == 0));
- /* Stop A/D conversion */
- ADC_STOP_CONV(ADC);
- /* Disable ADC comparator interrupt */
- ADC_DisableInt(ADC, ADC_CMP0_INT);
- ADC_DisableInt(ADC, ADC_CMP1_INT);
- /* Disable compare function */
- ADC_DISABLE_CMP0(ADC);
- ADC_DISABLE_CMP1(ADC);
- if(g_u32AdcCmp0IntFlag == 1)
- printf("Comparator 0 interrupt occurs.\nThe conversion result of channel 2 is less than 0x800\n");
- else
- printf("Comparator 1 interrupt occurs.\nThe conversion result of channel 2 is greater than or equal to 0x800\n");
- /* ADC interrupt handler */
- void ADC_IRQHandler(void)
- if(ADC_GET_INT_FLAG(ADC, ADC_CMP0_INT) != 0)
- g_u32AdcCmp0IntFlag = 1;
- ADC_CLR_INT_FLAG(ADC, ADC_CMP0_INT); /* clear the A/D compare flag 0 */
- if(ADC_GET_INT_FLAG(ADC, ADC_CMP1_INT) != 0)
- g_u32AdcCmp1IntFlag = 1;
- ADC_CLR_INT_FLAG(ADC, ADC_CMP1_INT); /* clear the A/D compare flag 1 */
- /* MAIN function */
- int main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- /* SAMPLE CODE */
- printf("\nSystem clock rate: %d Hz", SystemCoreClock);
- /* Result monitor test */
- AdcResultMonitorTest();
- /* Disable ADC module */
- ADC_Close(ADC);
- /* Disable ADC IP clock */
- CLK_DisableModuleClock(ADC_MODULE);
- /* Disable External Interrupt */
- NVIC_DisableIRQ(ADC_IRQn);
- printf("\nExit ADC sample code\n");
- while(1);
