[STM32F0] 关于stm32f030f4p6芯片的HSE问题
1688|8
 楼主| liaojunhui 发表于 2016-7-12 15:50 | 显示全部楼层 |阅读模式
各位大神,最近用stm32f030f4p6这款芯片时遇到一个问题,想要使用外部12MHz的晶振,但是却一直检测不到HSERDY位置1.
程序卡在了下面这一句
while(!HSEStatus)
   HSEStatus = RCC->CR & RCC_CR_HSERDY;    //¼ì²âÍⲿHSEÊÇ·ñÆðÕñ£¬µÈ´ýÆðÕñ
哪位大神能帮忙看看,芯片也换过了,12MHz的晶振用示波器也能看到12MHZ的方波。
(不知道上传代码,那段代码就和启动代码段的时钟配置是一样的)
void system_config(void)
  uint32_t HSEStatus = 0;
  RCC_DeInit();
  RCC->CR &=0xfffeffff;        //关闭HSE
  RCC->CR |=0x00040000;          //使用外部有源晶振,所以置位该位,旁路HSE,在该模式下,OSC-IN需要外部时钟源,OSC_OUT不接且不能作为IO管脚
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);      //开启HSE外部时钟
  while(!HSEStatus)
   HSEStatus = RCC->CR & RCC_CR_HSERDY;    //检测外部HSE是否起振,等待起振
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)      //外部时钟已起振
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == 0x01)
    /* Enable Prefetch Buffer and set Flash Latency */
    FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;    //SYSCLK=HCLK,不分频
    /* PCLK = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
    /* PLL configuration = HSE * 6 = 48 MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));     //此语句相当于先复位这三个数据
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL4);  //此处改成4倍频,HSE=12MHz
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;       //开启PLL锁相环
    /* Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)    //等待PLL锁相环开启
    /* Select PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
  else
    //while(1);
  /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
mmuuss586 发表于 2016-7-12 17:01 | 显示全部楼层
时钟的初始化部分不对呗;
淘宝上找些开发板的网盘链接,参考他们的代码试试看;
neeringstu 发表于 2016-7-12 21:30 | 显示全部楼层
你的时钟的初始化函数是怎么写的,估计没有初始化成功
 楼主| liaojunhui 发表于 2016-7-12 22:24 | 显示全部楼层
我的初始化时钟已经贴上来了,还请您看一下,是否是配置时钟时出了问题。程序是卡在while(!HSEStatus)这一块代码了@neeringstu
 楼主| liaojunhui 发表于 2016-7-13 15:22 | 显示全部楼层
原因找出来了,该芯片的VDDA必须要接3.3V电源
xmshao 发表于 2016-7-14 17:13 | 显示全部楼层
芯片上的那些电源脚不要漏网之鱼,不然无视了很折腾的。
Thorald 发表于 2016-7-14 18:34 | 显示全部楼层
可能是时钟的初始化不对
迪卡 发表于 2016-7-14 19:21 | 显示全部楼层
VDDA必须要接3.3V电源,VDDA是怎么定义的
