[STM32F7] 【STM32F767ZIT6评测】初步移植ucosii
1785|4
 楼主| 9robot 发表于 2016-8-22 09:13 | 显示全部楼层 |阅读模式
STM32F7已经完全抛弃了标准库的开发方式,只能采用HAL库开发。M7的性能很强大,FLASH和RAM也较大,如果只是裸跑的话,性能就有点浪费。本来打算利用STM32CUBEMX工具来移植FREERTOS,但是出现一些问题,没有成功。所以才去移植ucosii。移植的过程很大一部分参考了M4的移植教程。目前,只是初步移植,M7和M4的寄存器存在一些差别,后期还是需要修改,现在的模板可以正常运行。
  1. static void SystemClock_Config(void)
  3.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  4.   RCC_OscInitTypeDef RCC_OscInitStruct;
  5.
  6.   /* Enable HSE Oscillator and activate PLL with HSE as source */
  7.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  8.   RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
  9.   RCC_OscInitStruct.HSIState = RCC_HSI_OFF;
  10.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  11.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  12.   RCC_OscInitStruct.PLL.PLLM = 8;
  13.   RCC_OscInitStruct.PLL.PLLN = 432;
  14.   RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  15.   RCC_OscInitStruct.PLL.PLLQ = 9;
  16.   RCC_OscInitStruct.PLL.PLLR = 7;
  17.   if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  18.   {
  19.     while(1) {};
  20.   }
  21.
  22.   /* Activate the OverDrive to reach the 216 Mhz Frequency */
  23.   if(HAL_PWREx_EnableOverDrive() != HAL_OK)
  24.   {
  25.     while(1) {};
  26.   }
  27.
  28.
  29.   /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
  30.      clocks dividers */
  31.   RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  32.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  33.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  34.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  35.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  36.   if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7) != HAL_OK)
  37.   {
  38.     while(1) {};
  39.   }
  40. }
  1. void start_task(void *pdata)
  3.         OS_CPU_SR cpu_sr=0;
  4.         pdata=pdata;
  5.         OSStatInit();  //¿ªÆôͳ¼ÆÈÎÎñ
  6.
  7.         OS_ENTER_CRITICAL();  //½øÈëÁÙ½çÇø(¹Ø±ÕÖжÏ)
  8.     //LED0ÈÎÎñ
  9.     OSTaskCreateExt((void(*)(void*) )led0_task,
  10.                     (void*          )0,
  11.                     (OS_STK*        )&LED0_TASK_STK[LED0_STK_SIZE-1],
  12.                     (INT8U          )LED0_TASK_PRIO,
  13.                     (INT16U         )LED0_TASK_PRIO,
  14.                     (OS_STK*        )&LED0_TASK_STK[0],
  15.                     (INT32U         )LED0_STK_SIZE,
  16.                     (void*          )0,
  17.                     (INT16U         )OS_TASK_OPT_STK_CHK|OS_TASK_OPT_STK_CLR|OS_TASK_OPT_SAVE_FP);
  18.         //LED1ÈÎÎñ
  19.     OSTaskCreateExt((void(*)(void*) )led1_task,
  20.                     (void*          )0,
  21.                     (OS_STK*        )&LED1_TASK_STK[LED1_STK_SIZE-1],
  22.                     (INT8U          )LED1_TASK_PRIO,
  23.                     (INT16U         )LED1_TASK_PRIO,
  24.                     (OS_STK*        )&LED1_TASK_STK[0],
  25.                     (INT32U         )LED1_STK_SIZE,
  26.                     (void*          )0,
  27.                     (INT16U         )OS_TASK_OPT_STK_CHK|OS_TASK_OPT_STK_CLR|OS_TASK_OPT_SAVE_FP);
  28.     OS_EXIT_CRITICAL();             //Í˳öÁÙ½çÇø(¿ªÖжÏ)
  29.         OSTaskSuspend(START_TASK_PRIO); //¹ÒÆð¿ªÊ¼ÈÎÎñ
  30. }
  31. //LED0ÈÎÎñ
  32. void led0_task(void *pdata)
  33. {
  34.         INT16U VER;
  35.         VER=OSVersion();
  36.         while(1)
  37.         {
  38.                 HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_7);
  39.                 LCD_Printf(1,2,"%d",VER);
  40.                 delay_ms(300);
  41.         };
  42. }
  43. //LED1ÈÎÎñ
  44. void led1_task(void *pdata)
  45. {
  46. unsigned char i=0;
  47.         while(1)
  48.         {
  49.                 HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_0);
  50.                 i++;
  51.                 LCD_Printf(1,4,"%d",i);
  52.                 delay_ms(1000);
  53.         };
  54. }
UCOSII-M7.zip
1.34 MB, 下载次数: 13
mmuuss586 发表于 2016-8-22 10:19 | 显示全部楼层
谢谢分享;
lai832 发表于 2016-8-23 23:02 | 显示全部楼层
弱弱说一句,用uCOSII是不是浪费了?uCOSIII更合适
 楼主| 9robot 发表于 2016-11-3 09:09 | 显示全部楼层
用ucosii是有点浪费,但是我本身比较熟悉UCOSII,UCOSIII基本算是没用过,只是习惯问题
yong123321 发表于 2016-11-4 11:26 | 显示全部楼层
有木有ucosii的源程序啊
