收藏0 举报
/** \brief Enable External Interrupt The function enables a device-specific interrupt in the NVIC interrupt controller. \param [in] IRQn External interrupt number. Value cannot be negative. */ __STATIC_INLINE void NVIC_EnableIRQ(IRQn_Type IRQn) { NVIC->ISER[0] = (1 << ((uint32_t)(IRQn) & 0x1F)); } /** \brief Disable External Interrupt The function disables a device-specific interrupt in the NVIC interrupt controller. \param [in] IRQn External interrupt number. Value cannot be negative. */ __STATIC_INLINE void NVIC_DisableIRQ(IRQn_Type IRQn) { NVIC->ICER[0] = (1 << ((uint32_t)(IRQn) & 0x1F)); } /** \brief Get Pending Interrupt The function reads the pending register in the NVIC and returns the pending bit for the specified interrupt. \param [in] IRQn Interrupt number. \return 0 Interrupt status is not pending. \return 1 Interrupt status is pending. */ __STATIC_INLINE uint32_t NVIC_GetPendingIRQ(IRQn_Type IRQn) { return((uint32_t) ((NVIC->ISPR[0] & (1 << ((uint32_t)(IRQn) & 0x1F)))?1:0)); } /** \brief Set Pending Interrupt The function sets the pending bit of an external interrupt. \param [in] IRQn Interrupt number. Value cannot be negative. */ __STATIC_INLINE void NVIC_SetPendingIRQ(IRQn_Type IRQn) { NVIC->ISPR[0] = (1 << ((uint32_t)(IRQn) & 0x1F)); } /** \brief Clear Pending Interrupt The function clears the pending bit of an external interrupt. \param [in] IRQn External interrupt number. Value cannot be negative. */ __STATIC_INLINE void NVIC_ClearPendingIRQ(IRQn_Type IRQn) { NVIC->ICPR[0] = (1 << ((uint32_t)(IRQn) & 0x1F)); /* Clear pending interrupt */ } /** \brief Set Interrupt Priority The function sets the priority of an interrupt. \note The priority cannot be set for every core interrupt. \param [in] IRQn Interrupt number. \param [in] priority Priority to set. */ __STATIC_INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority) { if(IRQn < 0) { SCB->SHP[_SHP_IDX(IRQn)] = (SCB->SHP[_SHP_IDX(IRQn)] & ~(0xFF << _BIT_SHIFT(IRQn))) | (((priority << (8 - __NVIC_PRIO_BITS)) & 0xFF) << _BIT_SHIFT(IRQn)); } else { NVIC->IP[_IP_IDX(IRQn)] = (NVIC->IP[_IP_IDX(IRQn)] & ~(0xFF << _BIT_SHIFT(IRQn))) | (((priority << (8 - __NVIC_PRIO_BITS)) & 0xFF) << _BIT_SHIFT(IRQn)); } } /** \brief Get Interrupt Priority The function reads the priority of an interrupt. The interrupt number can be positive to specify an external (device specific) interrupt, or negative to specify an internal (core) interrupt. \param [in] IRQn Interrupt number. \return Interrupt Priority. Value is aligned automatically to the implemented priority bits of the microcontroller. */ __STATIC_INLINE uint32_t NVIC_GetPriority(IRQn_Type IRQn) { if(IRQn < 0) { return((uint32_t)((SCB->SHP[_SHP_IDX(IRQn)] >> _BIT_SHIFT(IRQn) ) >> (8 - __NVIC_PRIO_BITS))); } /* get priority for Cortex-M0 system interrupts */ else { return((uint32_t)((NVIC->IP[ _IP_IDX(IRQn)] >> _BIT_SHIFT(IRQn) ) >> (8 - __NVIC_PRIO_BITS))); } /* get priority for device specific interrupts */ } /** \brief System Reset The function initiates a system reset request to reset the MCU. */ __STATIC_INLINE void NVIC_SystemReset(void) { __DSB(); /* Ensure all outstanding memory accesses included buffered write are completed before reset */ SCB->AIRCR = ((0x5FA << SCB_AIRCR_VECTKEY_Pos) | SCB_AIRCR_SYSRESETREQ_Msk); __DSB(); /* Ensure completion of memory access */ while(1); /* wait until reset */ }
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
223
3792
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
