CM3这个内核是大小端可配置的:
The processor contains a configuration pin, BIGEND, that enables you to select either
the little-endian or BE-8 big-endian format. This configuration pin is sampled on reset.
You cannot change endianness when out of reset.
STM32是固定配置为小端的:
The bytes are coded in memory in Little Endian format. The lowest numbered byte in a word is considered the word’s least significant byte and the highest numbered byte the most significant.
