SPI2接收不到数据
2943|2
 楼主| edwinsong 发表于 2010-3-24 08:58 | 显示全部楼层 |阅读模式
spi, IO, ni, ST, gp
本人使用SPI2读写flash M25p32
配置如下
   /* Configure SPI pins: SCK, MISO and MOSI */
   GPIO_InitStructure.GPIO_Pin = SPI_FLASH_PIN_SCK | SPI_FLASH_PIN_MISO | SPI_FLASH_PIN_MOSI;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
   GPIO_Init(SPI_FLASH_GPIO, &GPIO_InitStructure);
   /* Configure I/O for Flash Chip select */
   GPIO_InitStructure.GPIO_Pin = SPI_FLASH_CS;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
   GPIO_Init(SPI_FLASH_CS_GPIO, &GPIO_InitStructure);
   /* SPI configuration */
   SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
   SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
   SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
   SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
   SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
   SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
   SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
   SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
   SPI_InitStructure.SPI_CRCPolynomial = 7;
   SPI_Init(SPI_FLASH, &SPI_InitStructure);
   /* Enable the SPI  */
   SPI_Cmd(SPI_FLASH, ENABLE);
数据发送给flash,m25p32已经回复数据,MISO数据口有波形,但是,接收寄存器内始终没有数据
ST_ARM 发表于 2010-3-24 17:36 | 显示全部楼层
读数据的程序贴出来。
fengyan81 发表于 2010-3-25 16:24 | 显示全部楼层
void FlashPageRead(u16 page,u8 *Data)
        u16 i;
        FlashWaitBusy();
        Select_Flash();
        SPI_Flash_SendByte(PAGE_READ);
        SPI_Flash_SendByte((u8)(page >> 6));
  SPI_Flash_SendByte((u8)(page << 2));
  SPI_Flash_SendByte(0x00);//3个字节
  for (i = 0;i < 528; i++)
                Data[i] = SPI_Flash_ReadByte();
        NotSelect_Flash();
u8 SPI_Flash_ReadByte(void)
  return (SPI_Flash_SendByte(Dummy_Byte));
希望能对你有用
评分
参与人数 1威望 +4 收起 理由
香水城 + 4
查看全部评分
