[STM8] 【转】stm32f105外部晶振由8MHz调整到12MHz库的修改
1054|1
 楼主| 一坨代码 发表于 2016-11-3 00:00 | 显示全部楼层 |阅读模式
1、首先是stm32f10x.h中的HSE_VALUE[cpp] view plain copy
  • #if !defined  HSE_VALUE
  • #ifdef STM32F10X_CL
  • #define HSE_VALUE    ((uint32_t)12000000)//这里修改为12MHz
  • //  #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */注释掉
  • #else
  •   #define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
  • #endif /* STM32F10X_CL */
  • #endif /* HSE_VALUE */
2、修改分频/倍频系数使系统时钟变为72MHz
在system_stm32f10x.c的void SystemInit (void)函数下有一个SetSysClock()继续找static void SetSysClock(void)下的SetSysClockTo72();修改后如下一段代码:
其中被注释掉的部分为原来的代码。
  • <pre name="code" class="cpp">    /* Configure PLLs ------------------------------------------------------*/
  •     /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
  •     /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
  •     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  •                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  • //    RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  • //                             RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
  •     //HSE =  12 PLL2CLK = (HSE / 3) * 10 = 40 MHz
  •         RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV3 | RCC_CFGR2_PLL2MUL10 |
  •          RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
  •     /* Enable PLL2 */
  •     RCC->CR |= RCC_CR_PLL2ON;
  •     /* Wait till PLL2 is ready */
  •     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  • //    /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
  • //    RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  • //    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  • //                            RCC_CFGR_PLLMULL9);
  •         RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  •         RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  •                                                             RCC_CFGR_PLLMULL6);
  • #else
  • //    /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
  • //    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
  • //                                        RCC_CFGR_PLLMULL));
  • //    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
  •     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
  •                                         RCC_CFGR_PLLMULL));
  •     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
mmuuss586 发表于 2016-11-3 10:46 | 显示全部楼层
谢谢分享;
